Menzerna PO91E
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Piloti, Mar 26, 2008.
  1. Piloti
    Piloti Virgin Detailer
    I'm wondering if anyone uses Menzerna Intensive Polish and finds it breaks down very quickly.
    This weekend I was using it with a Flex DA/orange CCS pad in 40 degree temperatures. I found I was lucky to get 2 passes before it broke down.
    Was it me?:thud:
  2. MadOzodi
    MadOzodi Nuba Guru
    Whoa, I'd think that's a bit too cold. Remember Menz was formulated to be used in a controlled climate, i.e., temp. constant assembly line or whatever.
  3. LanceM
    LanceM DB Forum Supporter
    I've only used it once. But, it was breaking down the same as SIP
    .92
  4. detaildoc
    detaildoc Guest
    I have used it several times with the Flex and the orange pad and it broke down pretty easy. However, the one time I tried it when the weather was around 55 degrees, it gave me hell, it did not break down easy, it dusted even more, and the haze was very hard to remove. Since, I never use it in temperature under 65 degrees.
  5. Piloti
    Bingo! :nod::nod::nod:
    DetailDoc, thanks for the confirmation!
    Since my machine experience is so limited, I was hoping someone would help with their expertise.
  6. detaildoc
    detaildoc Guest
    You're welcome!
