Menzerna po203s
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Simz, Apr 21, 2009.
  1. Simz
    Simz Any Rag Vehicle Washer
    I know some use it with white l.c. pad for medium buffing, and black for finishing, but can it be use with orange to get some extra cutting power?
  2. milabfocker
    milabfocker Jedi Nuba
    It can be used in conjunction with any pad you choose; however, I would opt for Menzerna Super Intensive Polish (PO83Q) if you are going to utilize a cutting pad. Reason being is that Menzerna Power Finish (P203S) is designed to provide cut comparable to Menzerna PO83Q and finish down similar to Menzerna Super Finish (106FA). Using a cutting pad will likely prevent you from achieving an LSP ready finish; therefore, you should reach for the Menzerna PO83Q and benefit from the slight increase in cutting ability if you will need to follow up with a finishing polish regardless.
  3. loudog2
    loudog2 Two Bucket System Washer
    Yes it can. You will need to use a couple more steps after that to finish the car down properly.
  4. Chas
    Chas DB Forum Supporter
    I agree, I used it with an orange pad needed a following step after that to finish it down LSP ready. Also if you get the chance I would do an IPA wipedown of the area because P0203S has some fillers in it and which may hide some minor defects that will come back at a later point or after a few washes. You may then need to either use it for another pass or so or finish it down even more somehow. This is not always the case though I have used it and found it got most if not all defects out.
    Chas
  5. Simz
    Nice, must off the time i will use white and black pad. But it cost less to buy 2 orange pad and getting correct cutting power then buy orange pad and a 50$ bottles.
  6. Chas
    true true
