What does this Product do? Does it actully work? I used it after Menz IP and Menz Nano and then used this for the 3rd step on a Blue Pad... I really dint notice anything... Anyone used this product? Thanks
Menzerna Finishing Glaze is a water-based emulsion of glycerin, mineral oils, and Kaolin clay. The clay fills in minor imperfections while the oils give the paint a wet shimmer. The wax or sealant applied over the glaze will allow the filler to last longer and lock in the bright shine.
all it does is fill in imperfections. say if you had some light swirls on your car, but didn't want to polish, you would use this glaze, or any other glaze.
Agree - I found out the hard way. I have a brand new quart that I don't know what to do with... :shrug:
Glaze is not a polish since it contains no abrasives. It's supposed to be used as a "cover up" if you have minor swirls. Glaze will fill the swirls and add a luster to the paint which is why show cars tend to use it. Consider it "makeup" for a car less than perfect car.
