Melted Rubber on 3M Clear Bra.
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Nikku, May 16, 2010.
  1. Nikku
    Nikku Jedi Nuba
    Anyone come across a serious case of melted rubber on PPF?
    If so does anyone have non evasive solutions that do not involve damaging the PPF :)
    Appreciate the help.
    Cheers,
    Nick
  2. richy
    nick...got access to a steamer? That's the only thing i can think of..
  3. pektel
    pektel DB Forum Supporter
    Would a steamer have an adverse effect on whatever holds the ppf film onto the paint? I have very little experience with ppf film, so I'm just asking.
  4. togwt
    A dry vapour steamer should be fine, just keep it moving, Alternativly try a heat-gun or a hair-dryer
  5. Nikku
    Nikku Jedi Nuba
    Thanks for the reply guys. Appreciate it.
    Dave provided the suggestion of Tarminator. I'll give the steamer, heat gun and tarminator a try.
    Cheers
    Nick
  6. Zookie
    Zookie Jedi Nuba
    i wouldent use Tarminator... i used it on mine and it stained my 3M, its like itched in there... Its much more noticeable under White Light
  7. AZN_C300
    AZN_C300 Birth of a Detailer
    For one of my shows, they had out team situated really close to the drift competition. This resulted in melted tire particles all over the car and the clear bra. Basically I just gave it a good clay job and removed all of it with no issue.
  8. Nikku
    Nikku Jedi Nuba
    Sorry guys I meant to say I will be giving the solutions a try on my truck.
    Thanks for the additional tips. Thanks for the warning Zookie. I'll apply it via MF rather spray it onto the 3M to see if that makes a difference.
    I'll add claying to things to try on the 3M.
    Thanks for the responses guys.
  9. ndrom
    ndrom Two Bucket System Washer
    I would try clay, but you will most likely need to polish the PPF after.
