Scratch X Meguiars SCRATCH X Buy One, Get One Free! Swirl X Meguiars Swirl X Swirl Remover, SwirlX, car polish, Meguiar's Swirl Remover, Meguiars polishes, meguires, megwires My car has light swirls and I was just wondering which one is better to use. I have a feeling scratch x is more for deeper scratches... O and also, I don't have a DA so I plan on doing this by hand =)
Are you planning to get a porter cable or flex in the future? If so I believe the Menzerna line can be used by hand also and you can use it with a DA if you get one. Also, if you do buy either one of those two products, I'd recommend you to go to walmart or autuzone, it's cheaper there than AG with shipping.
The AutoGeek BOGO ScratchX is the older version with diminishing abrasives. Instead, go to WalMart or Advanced Auto and get the new formulation, ScratchX 2.0. It is considerably stronger and more effective, at least so I have read. It is also stronger than SwirlX: see Aggressiveness Order of 2009 Products.
I probably don't plan on buying DA so everythig will be by hand. What do you guys recommend using if not meguiars?
