Megs apc on wheels/tires
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by sweetlou, Jan 15, 2009.
  1. sweetlou
    sweetlou Two Bucket System Washer
    What is a good ratio for this to use on wheels and tires? Is apc even good for wheels? Also is it fine to use on chrome wheels?
  2. BrendanS
    BrendanS Welcome to Detailing
    im far from a pro, but a lot of detailers use APC for the rims as well as tires. Depending on which one, I would say most should be safe. Megs recommends 4:1 for heavy cleaning and 10:1 for light don't they?
  3. spK
    spK DB Forum Supporter
    I use to use 4:1 but switched to 10:1 since it had the same cutting power IMO. As for tires, I use amazing roll off.
  4. er1k
    er1k Obsessive Detailer
    When I ran out of ARO for my tires I went to Meg's APC 4:1 and it works great. Not as good as ARO but good enough.
  5. Bunky
    Bunky Guest
    Is Meg's safe for all factory wheels (chrome, painted, etc)
  6. supercharged
    Megs APC is much safer then Wheel Brightener. I use it on wheels very often, 4:1 with a foaming sprayer. Cheap, effective, safe, and it works...But if you have uncoated alluminum wheels, that sucks. You would have to use P21S wheel cleaner, which is quite pricey.
  7. DieselMDX
    DieselMDX Obsessive Detailer
    10 to 1 for me if the wheels are bad i use Super degreaser 4 to 1
  8. sweetlou
    Hmm, looks like I'll try between 4-1 and 10-1. Just seems easier to use on wheels tires and wheel wells rather than a wheel cleaner, tire cleaner And wheel arch cleaner
  9. Erik Mejia
    Erik Mejia Obsessive Detailer
    4:1 is great on both wheels, and tires... just make sure to use high quality brushes for both surfaces.
    APC is a great way to clean chrome wheels because it rinses well, and chrome won't be harmed by it.
  10. sweetlou
    i have a good tire brush, and just picked up a megs slide lock brush for the wheels, as well as an ez brush for the inners.
  11. mrgolfrider
    damn it, looks like i'm going to have to purchase ANOTHER megs slide lock for my wheels now, I think that will make 4 in my collection.
  12. scottBT
    scottBT Birth of a Detailer
    the sidelock brush is ok if your wheels arent baked in brake dust sometimes a little more pursuasion is needed.
    ive found plenty of stockists supplying swissvax/zymol style brushes for as little as £1.50 gbp and 5 brush sets for £10.00 gbp which is good value in my eyes.
    so long as the apc's arent caustic most will do the job its all down to the dillution, a general 4:1-6:1 will cut the grain:thumb:
  13. EisenHulk
    EisenHulk Birth of a Detailer
    I like using Megs APC cut 4:1 for tires...however, IMHO, few things work better than Eagle One A-Z Tire Cleaner...including ARO.
  14. junebug
    junebug Jedi Nuba
    Bunky - you're right in Raleigh - drive over to Majestic and get some Super Green - 1:1 for tires/wheels.
