After reading some posts here I thought I would give the Lusso Glass Polish a try. The product comes in a pump type spray bottle, but on the back of the bottle it says you should mix it and gives the ratios. Those of you that use this product do you know if you can just use it straight out of the pump? And if so, what are your results?
its just a glass cleaner that is amazing... its not a polish... spray on and wipe it off with a good glass microfiber towel
I agree with what Phil said. Definitely use it straight. It's my favorite glass cleaner, and I've tried many.
For actually polishing the glass I use Werkstat Prime Strong on my Flex w/ a black pad, then follow up with Acrylic, and then Glos to get rid of the streaks. Looks AMAZING, and beads/sheets like no other too!
I didn't want to start a new thread so I'm reviving this one. I've seen several different dilution ratios for this and it has me a little confused. This is off Lusso's website: "Lusso Glass Polish is a concentrate. Mix 4 to 1 with water for normal conditions, new cars or heavy smokers will benefit from a 2 to 1 ratio." And then this was off another page of their site: "The concentrate should be mixed with one part cleaner and ten parts clean water. For a brand new car, we suggest using a stronger mixture with three parts water." It just seems like these ratio's are pretty random and I've never come across a glass cleaner that came with different dilutions. I'd really appreciate it if someone could clear this up for me
