Looking for some glaze feedback
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by jaybs02, Jan 27, 2008.
  1. jaybs02
    jaybs02 Virgin Detailer
    I was hoping to get some feedback on a couple of different glazes.
    CG's EZ cream glaze
    FK1's 303 or 300
    Danase's wet glaze
    Clearkote's RMG
    I have heard people making "pink" glaze by mixing 50/50 RMG and VM so that might be a thought also.
    I was looking at Menzerna Finishing Glaze PO 115C, but it said that it has "just oils and fillers" and I am planning on topping the glaze W/ UPP this year and it sounds like there may be some bonding issues.
    Any and all feedback is appreciated.
    Thanks
    "J"
  2. Obsessive Detail
    You should check out my OD Wet Glaze. This is an acrylic glaze, so a sealant will bond to it just fine. It also adds a little bit of protection. It gives some really nice depth and wetness too.
  3. Dannyk
    Dannyk Jedi Nuba
    Good question, as i was looking for a response also. I was looking for a glaze (s) that would work for a non synth product (carnuba wax) And one that works with a synth. wax. With new products and finishes, it's prudent to keep up to speed for maximum results.
  4. FMINUS
    FMINUS DB Pro Supporter
    EZ Glaze is the best glaze hands down. I have NO COMPARISON!
  5. tdekany
    tdekany Wax on..Wax off
    I will second that. Best single product in detailing in my mind.
  6. LanceM
    LanceM DB Forum Supporter
    is this the same for the ez cream glaze II?
    So, EZ cream glaze will bond to the surface and can be top with an lsp AND the lsp will bond to the glaze?
  7. tdekany
    yes to both.
  8. jshillin
    jshillin Birth of a Detailer
    I have DWG, RMG, VMG, Megs 7 and Menzerna Finish Touch Glaze.
    I prefer DWG over the rest... I really like the look and the fact that I can top it with anything.
  9. LanceM
    well just made an order from CG for EZ, towels and wash.
  10. Z06-Goose
    Z06-Goose Any Rag Vehicle Washer
    Prima Amigo, RMG, and DWG are my favorites...
  11. togwt
    Danase Wet Glaze ( a polymer-based glaze) a pure gloss enhancer, it sure isn't a glaze like you have ever used before.
  12. jaybs02
    Thanks everyone for the feedback
    "J"
  13. detaildoc
    detaildoc Guest
    Love the DWG. Adds tremendous wetness and depth and you can put under on over anything and super easy to use. I keep several bottles of this stuff at any one time. I am curious though if anyone has used Prima Amigo. It is supposed to have some good filling abilities, but I wonder if it mutes flakes on metallics. Does anyone know?
  14. sal329
    sal329 Nuba Guru
    I like DWG and Prima Amigo. I use Amigo mostly for solid dark cars, no other reason then DWG looks great on metallics.
    I hope to detail my neighbors metallic red Explorer in the next few weekends I was plannin on using Amigo to see how it works with that color.
  15. detaildoc
    detaildoc Guest
    Post the results and your review of it on Metallics paying close attention to the flakes.
  16. Woob
    Woob Jedi Nuba
    Anyone try using Poorboy's Black Hole?
  17. JLs Detailing
    Smartest man on the forum!
  18. Denzil
    I'm curious how good the PB's Black Hole and White Diamond are...
  19. detaildoc
    detaildoc Guest
    Does EZ Creme have any filling abilities? Can you apply it over any sealant or wax or top it with any without bonding issues?
  20. wise 85
    wise 85 Virgin Detailer
    It has minor filling abilities,and can go under any sealant or wax!
