Are there any alternatives to using the Bissel cleaning solution? Wondered if anything else was good/better than the Bissel product in the machine. Also, what proportions if something else is used or just the same as the Bissel cleaning product? Thanks, G
I have a Bissell and think that is one of the best buys I have ever made. You can use CG Lightning Fast Carpet and Upholstery Stain Remover.
you can use any low foam or no foam carpet cleaner....one good one is the ZEP extractor shampoo..or just the plain carpet shampoo...both cheap and they make a lot of solution with the ratio cut... they also do a great job of cleaning...I use it in my Mytee extractor on the house rugs at times ..and does a real nice job..and they are cheap...like 8.00 a gallon and it dilutes also... get it at Home Depot.....the ZEP citrus APC works well also ..for some stubborn stains... Al
I have sprayed mats down with Folex and just used hot water in the LGM. Worked like a charm. A cleaning solution is not always needed in the LGM tank.
