1. er1k
    er1k Obsessive Detailer
    I am all of a sudden having some troubles with my Bissell.. the carpets are becoming dark when I am vacuuming them.. am I spraying to much?
  2. Chris@Optimum
    Are you using a cleaner in the tank or just water.
    I spray on the cleaner, scrub, then water only in the bissell to remove the grime and cleaner. If you apply a cleaner and don't rinse, it will probably attract dirt.
  3. er1k
    Using a cleaner mixed with water. Then I spray on to the carpet and let it sit for a minute or so, then scrub up the cleaner. But it leaves some dark spots:scared:
  4. Chris@Optimum
    Try my way and see if it's the same. Spray on your cleaner from a sprayer, not the LGCM, then scrub it it b4 you let it sit for better penetration, then extract with the LGCM filled only with hot water and maybe one ounce of white vinegar.
  5. er1k
    I'm going to try this out. Thanks for the help!
  6. Chris@Optimum
    No Prob! I hope it fixes your trouble, let me know.
