I dilute the strong 1:1 with distilled water and it works well and saves money. If I need something more I just use the strong straight.
yes Mutlimaster/Leathermaster states to dilute it. so I decided not to carry the soft cleaner. thanks 1f1fan!
Nubuck Foam Cleaner is a solvent free pump action product, which is extremely efficient for the cleaning of leather upholstery. The advantage of foam applicator over liquid is the minimum amount of moisture; foam also encapsulates soil enabling it to be wiped away without being re-introduced to the surface. The foam created by an aerosol or pump type dispenser has the consistency of shaving cream, making it ideal for leather ( especially sensitive finishes such as Aniline, Alcantara®, etc). Do not allow to dry as it can leave spot marks. For heavily soiled areas, or where the leather has become ingrained such as in creases in the leather, a soft brush can be used to agitate and loosen the dirt. Spraying a cleaner on hot leather can cause spotting and discolorations. Please remember, that by rubbing hard on the leather surface, you will only push the dirt deeper into the leather A wipe over with a damp cloth on a regular basis (every week/two weeks) is recommended to remove surface dust and dirt and add moisture to the leather. Alternative product - Auto Rapid S Cleaner - conveniently packaged with a foam producing pump; dispense foam onto the car seats. Work foam into the surface with a dampened sponge. Allow to sit for one minute and wipe the foam away with a clean cotton towel or soft paper towel. Auto Rapid S Cleaner - multimastershop.com - Home
I found a wonderfull website that has a ton of the leathermaster cleaners more than I have ever found. colorproleather
I think LM Soft Cleaner would be a little inneffective for cleaning auto upholstery. Their Strong Cleaner would be a better bet not diluted and you could even use a stronger one than that quite safely.
