LastBit Quicken Password Recovery 11.0.8050
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by NhocCuteGirl, Feb 8, 2011.
  1. NhocCuteGirl
    NhocCuteGirl Banned
    LastBit Quicken Password Recovery 11.0.8050When you lose your password for an Quicken file and have to recover it, Quicken Password is the tool of choice. The new improved password recovery engine is optimized for multi core CPUs and allows to achieve the best possible performance. There are two types of passwords used in Quicken: a password for opening a data file (also known as 'file password') and a transaction password. If both passwords are set, you will have to find the password for opening the file first; then you can decrypt the transaction password. In other words you cannot decrypt the transaction password if the file password is set. It is possible to recover the transaction password instantly. Fake Password will be constructed. Unless your document was created in an old Quicken (prior 2001), the password for opening is much, much harder to crack. The universal recovery methods (Brute Force Attack, Dictionary Search and Smart Force Attack) must be used for that. Unfortunately, even a single password check takes a lot of computations, so the search speed will be very slow (not more than 1000 passwords per second). This means that the recovery of even a relatively short password will take A LOT of time. LastBit Corp. proudly presents Guaranteed Recovery Service for Quicken. Guaranteed Recovery Service uses the power of multiple computers, this will be equal to spending 6+ months of computations on a single computer. This significantly improves chances to find a password.Requirements: A standard Windows PCWhat's new in this version: Improved password recovery engine. Guaranteed Recovery Feature is available.
    download here
    Download Link:
    Code:
    http://soft444.com/2010/12/05/lastbit-quicken-password-recovery-11-0-8050/
