LanceM Detailed: 2007 Black MB Swissvax and Z*mol
Discussion in 'Show and Shine' started by LanceM, Apr 20, 2008.
  1. LanceM
    LanceM DB Forum Supporter
    This detail was for an important client. My mom. My bro and I bought her this car after we got our jobs after college. So, I decided to hook her up. She sometimes brings it to the swirlomatic even though I tell her not to. She says she doesn’t want to bother me cause I’m busy. I usually try to hide the swirls with concorso. I completed this detail in few days. I took my time and had to take breaks due to weather (I wish I had a garage).
    I initially started on the interior. The interior wasn’t bad, due to the use of the floor mat covers. However, the light color shows dirt so easily.
    Before Interior:
    I started by dusting the interior with a static cloth and also cleaned the interior with a swissvax brush.
    I then vacuumed the interior. After that I shampooed the carpets with Meguire's All Purpose cleaner diluted 10:1. I also used this solution as a cleaner on the rubber pieces.
    Carpets shampooed and wet vac'd:
    Next I dressed the rubber/plastic interior parts with 303 Aerospace. It left a nice finish and I buffed off any excess for a natural look.
    I then cleaned the windows with IG and with a detailers domain glass cloth. I really liked this cloth as it picked up all the IG and left a nice streak free finish.
    I then wanted to address the wood panels. The wood had fine swirls and scratches. However, I could not get a good picture of these. I used Swissvax cleaner fluid on the wood panels and buffed off. This left a very nice luster as usual. It also filled in the fine swirls and scratches. I then applied Swissvax wood polish. This stuff smelled good and also was easy to work with (just like the SV waves). I applied using a CG foam applicator and let it sit for 5 minutes and buffed off with a DD MF. I really liked the finish the wood polish left.
    Next, I used Swissvax Leather Cleaner and brush to clean the leather. I noticed the cleaner cleaned very well especially using the brush. The dirt and stains were removed pretty easily. After this, I used an applicator to apply Swissvax Leather Milk. I applied and let it sit for 30 min. The leather milk left a nice matte finish and also left the leather nice and supple. Comparing the Swissvax leather products to the zaino I used. I like the results of the Swissvax better, but the smell isn’t really appealing. Smells more like a chem than Zaino. But, the smell faded away and left the interior smelling neutral.
    Here are the after pics of the interior.
    After the interior was complete, I decided to do the wheels. I had a request to rotate and check the pressure of the tires, so I got the floor jack and jack stands out. While, I was there I decided to clean the fenderwells and undercarriage with Megs APC 4:1 and dress it with CG Bare bones. The rear fenderwell was lined with carpet. Megs APC 10:1 then Vac.
    The wheels were cleaned wiith P21S wheel gel and agitated with a sponge, swissvax wheel brush, q tips and foam finger covers. After they were clean, I applied Swissvax Cleaner Fluid and waxed with AutoBahn.
    After the wheels were done, I torqued all wheels to 80 ft/lbs and then moved to the engine. I used Megs degreaser and APC to clean it. Then dressed with 303 Aerospace on the plastic and Honda shin-etsu grease. I use this on my seals on the s2k aswell.
    I started rinsing the car, when I noticed the trim by the windshield was dull. I applied a pea sized amount to an old NXT applicator and spread. I really liked the results.
    After rinsing, I foamed with a high concentration of CG CWG and washed with this also. I then clayed with Meguires blue medium clay and lubed with mothers. There were quite a bit of swirls from the swirlomatic and various scratches. I also noticed trim was heavily oxidized. I polished the trim and it left a few of my pads black :(
    I decided to try SIP and an cobra crosscut orange pad. I thought these pads were pretty good. After SIP, I checked with the brinkman and saw some good results. I brought the car out in the sun and I still saw swirls. I went over with SIP and an orange with the flex at 5.5 again. I noticed SIP didn’t react to well at 6. I finished using the udm with FP with a blue pad. I did this for the whole car and lamps. I tried a test area with Powergloss and a yellow, but the results were tons of marring.
    Corrected
    Uncorrected
    I then polished the glass with 1z glass polish. I used the the udm with a white pad on a low setting. The glass polish was liquid. Surprised me at first. I then finished the glass with rainx.
    I then wanted to try out my zymol screen and lens. The fluid cleaner smelled and looked like HD cleanse. I’m pretty sure they are the same. I applied and buffed the cleaner off and then applied the wax. The wax was blue and left to haze for 5 min and buffed off. The lens looked better, but probably not noticeable in the pics.
    I then applied Swissvax Pneu to the tires. I liked this stuff. I sprayed on the tire, spread with a foam pad, let sit for 5min and then buffed off. I liked the look it left. Semi shine and natural look. Smelled like concorso. lol
    Now it was time to apply the LSP. I chose to use Z hd cleanse and Z Vintage. I thought I was prepared for HD cleanse from my experience with cleaner fluid. Man was I wrong. HD cleanse was a pain! I finished the car swearing and hating this stuff. I wont use it again. I applied Vintage to the s2k without it and didn’t see a difference.
    Vintage is a soft wax. I was surprised how soft it was. It went on real easy and noticed a little went a long way. After letting it sit for 5min and buffing off. I then let the car sit in the sun for 3 hours. I hear about the sweating that goes with this wax, so I put field glaze in the freezer for about 10 min and then applied to the car to remove the oils. The reflections and clarity were great. My neighbor kept saying it was very deep. I'm still deciding how much I like this stuff better than concorso. Give me a week or so and I'll give a better review. Please pardon the pollen as it was sticking quickly.
    No scratch anymore
    The trunk cleaned up nicely :)
  2. Smith2287
    Great detail, I am sure your mother loved your work. Zymol waxes have always interested me but I never used them before, I been sticking to my various swissvaxes. I had no clue that the clense is that hard of a product to use, and is an interesting factor I am going to consider before ordering zymol waxes.
    Again great work and awesome write up as well.:applause2: And yes I know not having a garage is the worst.
  3. Cooter
    Looks great Lance. The fenderwheels look really really nice! The black looks deep. Great job.
    How long did the job take??
    Heath
  4. LanceM
    She loved it.
    I still love swissvax, very easy to use and no extra buffing necessary. I hate hd cleanse. I will have some for sale. lol Field glaze was very nice though. Brought out some some good reflections.
    Didnt really keep track. I spent this weekend doing it. I took my time though.
  5. Mindflux
    Mindflux Welcome to Detailing
    Great work. What's that bulb or whatever you are using on the Meg's APC?
  6. LanceM
    thanks. Pro blend bottle proportioner. I got it from AG
  7. GBS
    GBS Wax on..Wax off
    Very nice job all the way around Lance. It 's great to see other people pulling the wheels off and detailing the wheels and wells. My wife's E500 has that same color interior. It's a PITA to keep clean. I ended up getting some OEM black floor mats for it.
  8. Mindflux
    I thought that's what it was but I had never seen one before.
    How's that APC by the way? I still have a bottle of the old APC+ (Blue) that smells like urine.
    :yikes:
  9. LanceM
    I like it. I always use it from carpets to whatever. This one cleans well and smells clean as opposed to urine lol
  10. LanceM
    man. this interior is a pain. I knew it when we were buying it. We wanted black on black, but it was the only one with the options we wanted. Thanks!
  11. JLs Detailing
    Lance that is an awesome job. Man you did a fantastic turnaround on the car. Your review and write up is very helpful, thanks for that. You do some damn fine work there and the car looks incredible. People are getting some fantastic results from Vintage.
  12. LanceM
    thanks alot! I really like vintage :)
  13. Usjdmtuner
    Usjdmtuner Wax on..Wax off
    wow top of the line.. zymol plus swissvax is two thumbs up.. love the interior detail and wheel wells...
  14. LanceM
    lol when it comes to mom you gotta use the good stuff. Thanks alot!
  15. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Great job on the Benz Lance.
  16. Usjdmtuner
    Ofcourse you gotta love the moms.... You are one good son.. Glad to see that you are spoiling her with good stuff... Continue the good deeds..
  17. J BELL
    J BELL Nuba Guru
    Yeah yall buying her that car after her hard work raising you was a very kind gesture to say the least...at least the whole world isnt filled with punks..hats of to you for what you did and a great detail!
  18. LanceM
    thanks alot. she did a good job raising us. It was the least we could do.
  19. detailersdomain
  20. Nica
    Wow what a detail well done :applause: :applause:
    Removing the rims and taking care of the wood trim like that, now that's detailing well done :worship2: :worship2:
    Oh if you think regular HD Cleanse is a paint hahaha if you ever get your hand on HD Pro man that's like 10x worse then regular HD lol. Thing is that Zymol products are very picky and I've found that you have to stick to there process otherwise you don't get the results your after....well that's just what happend to me :shrug:
    Vintage is a great wax, it definetly delivers. Vehicle looks great, I like the curves on this car :thumb:
    I enjoyed your write up, well done :applause:
