Klasse AIO - Hand or machine?
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by Xcessiv, Dec 3, 2008.
  1. Xcessiv
    Xcessiv Birth of a Detailer
    Hi guys,
    What's your personal experience using both methods? Which one gave the best result?
    Also, is it ok to use AIO without SG on beater cars just to add reasonnable shine and protection?
    Thank you.
    Regards,
    Yan
  2. jetblackZ4
    jetblackZ4 Birth of a Detailer
    This is just my personal experience but I've done it both ways and I don't think there was any difference. Sure you can use AIO without SG and it will make the surface much smoother and give it some shine. As far as protection goes, I'm not sure how much protection it will give and I've never done just AIO without topping it with other sealants and/or wax.
    Lets see what others think.
    G
  3. Reflect
    I was under the impression that AIO had sealant properties to it.
  4. Cleaning Fool
    Cleaning Fool Birth of a Detailer
    Klasse will add protection, maybe 1 month durabilty. I'll take machine and its results over hand every time
  5. Xcessiv
    Thank you for the replies! More questions...
    1) Does KSG react well over Poli-Seal, even if Poli-Seal contains some Karnauba?
    2) What would give the best looking result?
    a) Nanopolish + KAIO + KSG
    b) Poli-Seal + KSG
    3) In question 2), does a) justify the large price difference over b)?
    4) How durable are the fillers in KAIO + KSG? I'm not talking about how durable is the protection, but the fillers hiding light swirls.
    5) What has more cutting power between Nanopolish and Poli-Seal?
    Thank you.
    Yan
  6. togwt
    Application- The secret to the application of a polymer product and to obtain optimum results: is to apply it thin (super thin) fill a spray bottle and mist a foam pad for application. It cannot be emphasized enough ‘Apply products very sparingly’ Ease of product removal is inversely proportional (less product easier removal) to the amount used (0.5 – 1.0 oz should be sufficient for most vehicles)
    Using an ultra soft foam (CCS Gold 100 PPI foam pad) – a very soft, imported foam is ideal for applying an ultra thin coat of polymer sealant, the foam works especially well when applying sealants because it is firm enough to keep the majority of the product on the paint, rather than soaking it up.
  7. Xcessiv
    And what about the previous questions (Optimum vs Klasse vs Menzerna, + combinations)?
    Thank you.
  8. RamSus
    RamSus Jedi Nuba
    I'm also curious about this. Could any of the experts here provide any feedabck you may have.
    Thanks
