KIA Sorento (lots of Pics!!!!)
Discussion in 'Show and Shine' started by Tonya, May 4, 2008.
  1. Tonya
    Tonya Welcome to Detailing
    I didn’t get a good luck at this one before she dropped it off. I did a Vette a few weeks ago and I she sent me her mother’s KIA. ED…. I know I tried to tell you the pollen was bad… but this is what kills me!!! Anyway….. I started on the interior, since it was raining. :shrug: She told me the vehicle was bought used and someone had smoked it in. I said I would see what I could do. I started with a Meg’s quick detail wipe down. It was not that dirty and I love the smells of that stuff!! I wiped everywhere my hand would fit and steam cleaned the carpet. Steamed the vents and used Jax Wax Dash vent Magic. This stuff smells awesome! Did a light wipe down of the headliner. Richy....I did my best to keep a time of some areas. I hope you guys can tell me where I need to speed up my time. There were only a few areas that I really tried to correct. The rest of the vehicle I was just trying to get light swirl removal.
    Products used:
    Interior (total time 3.22)
    Meg’s quick Interior Cleaner
    303
    DG leather Cleaner
    4 Star conditioner
    Stoners invisible Glass
    Floex
    ARO
    Steamer and little green machine
    Exterior
    P21S ~ rims (total time 27 minutes)
    SCG Road Trip Destroyer Diluted 1:1 in garden sprayer ~Wheel Wells
    ARO ~Tires
    ONR wash (total time 1.22)
    DG 501 as tar remover (18 minutes)
    Pinncale lube (total time 57 minutes)
    Pinncale Ultra Poly Clay (57 minutes)
    Taping ( 46 minutes)
    XMT 3 cut with DG 501 mixed 3:1 (total time 3.18)
    XMT 1
    :thud: Second ONR wash ( 34 minutes)
    Engine ( 42 minutes) Damp MF La’s Awesome dressed with 303
    Trim dressing Black Now / Tires CG VRP ( 28 minutes)
    Windows inside and out (22 minutes)
    DP Surface Shield (Darn forgot to keep track... :shrug: not long :giggle:)
    That was my time line to the best of my ability to keep track. :shrug: I get distracted :giggle: Here a some pics to explain my process.
    Vac and pretreated stains with Floex
  2. FMINUS
    FMINUS DB Pro Supporter
    Great detail!!!!!!!
  3. LanceM
    LanceM DB Forum Supporter
    looks great!
  4. 02CAMSS
    02CAMSS Jedi Nuba
    Nice job!!!!
  5. MadOzodi
    MadOzodi Nuba Guru
    Fantastic! Whatever spilled in that one pic left something nasty!
  6. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Great job Tonya.
  7. Deep Gloss Auto Salon
    Looking good tonya
    the things I pm'd you should shave a good 2 hours off your process with out comprimising quality - simple process efficiency
  8. richy
    Tonya..really really nice job there! The lights came out nicely too. You asked me to look at your times. I did and FWIW, you get what you pay for. Although in general you get faster without sacrificing quality as you do more volume, I go back to "you get what you pay for"...if it's rough and needs a lot of work, so be it. As long as you can estimate (or give a range) and the customer agrees to it..you good to go. It takes a long time to make a silk purse out of a sow's ear!! Looking at your times, a few things do come to mind:
    taping at 46 minutes seems like a lot. I will often only tape a little bit (black plastic moldings always need it) if I'm using foam pads. Even if I do a whole car, I would think 20 minutes is plenty. You will use less tape as you get more confident with a rotary. This knocks off a bit I guess.
    the wheels seem in order..I usually spend an hour (sometimes more) to do all 4 wheels, wells and tires.
    another area where you can save time is after doing the wheels, power wash the exterior, wash the vehicle and bring it inside. If you are going to clay, there is really no need to dry it off prior to claying. This will cut off some minutes, too.
    the interior is a crap shoot. Nasty stains like you had just take time..that's all there is to it. I currently pw the mats while I wash the car and have the pw out. that way they have time to dry after cleaning and vacuuming them. I usually take 1.5 hrs to wash (wheels included) and do the mats.
    Try a dedicated bug/tar remover spray like the DG one...it should save you a few minutes there too.
    The bottom line is that people get what they pay for. You're using the right equipment (ie Rotary is somewhat faster than Da's and for heavy correction, wool is faster than foam) and that helps. I would rather eat a small amount of time on a job ( I ate 2 hours on that Mustang on Friday) than put something out that I knew could have been done better.
    You don't need to apologize for your quality; it's first rate. Don't make an issue out of the time too much. As long as you're enjoying yourself (I'll recommend the cigars again, LOL) and find the job rewarding (I know you do), then the $$ is really secondary. Hope that helps.
  9. er1k
    er1k Obsessive Detailer
    Fantastic job! That thing really shines. And a great turnaround on the interior!
  10. Black Diamond
    Black Diamond Jedi Nuba
    You are a natural Tonya!
    Keep up the fantastic work.
    Each detail that you do will get faster and easier.
  11. Jimmie
    Jimmie Birth of a Detailer
    Wow, another impressive detail Tonya. Enjoyed your write-up too.
  12. pirex
    pirex DB Certified Dealer
    Very nice work Tonya, the kia looks great! Now go buy Menzerna!!
  13. Nica
    Nice turn around Tonya :peace:
    I enjoyed your write up :thumb: thank you for sharing with us.
  14. GBS
    GBS Wax on..Wax off
    :loud:Your putting out some fine work Tonya!
  15. Pats300zx
    Great job Tonya. It looks like your business is booming. I am very happy for you.
    I can see you running around with your stopwatch :)
  16. supercharged
    Great work, Tonya! Inside and out! Two thumbs up!
  17. distrbd
    distrbd New Member
    Tonya,I don't want to just say "good job" because your work shows you don't compromise "the job" to make a quick buck,you show a lot of patience ,and do the right thing so you can put your own stamp of approval on the work you did.
    Without a doubt those who appreciate quality work will call and give you more work.
    Well done.:applause:
  18. zoomzoom mazda5
    Great recovery on the KIA Tonya, i might be calling my friend in Fairborn to see if he needs a detailer for his ride. You are getting better each time i see one of your threads!........:applause:
  19. Al-53
    Al-53 Welcome to Detailing
    Very nice detail Tonya.....and yes the rotors where rusty...lol......great job all around....everything looks tip top ...
    Oh...get a dedicated bug cleaner like the Dg bug cleaner..and stop using a great product like 501 to remove tar..thats a sin...lol.....the Dg bug remover works well..just spray it on before you wash.let it dwell a few minutes...rub it a little and then wash....
    Very nice work
    A++++
    Al
  20. Tonya
    Thanks!! :shrug: I am not sure.... maybe coffee :shrug: No biggie I got it :thumb:
    Thank you!!
    Got it thanks you!!!!
    Thank you!
    Thanks! I hope I get faster! :thud:
    Thanks!! Your welcome buddy :thumb: gald you like it!!!
    Thanks! OK....OK...I will get some... stop yelling at me!!!! :giggle: j/k I will I promise!!!
    Thank you!!! Glad you like it :applause2:
    Thanks Gary!!!
    hehehe LOL Pampered Cheif kitchen timer and post it notes :giggle:
    Thanks you!
    Thanks you!!!
    Thank you very much!!! Heck.. Fairborn is a stones through away!!! :giggle:
