Japanese Products
Discussion in 'Car Detailing Product Discussion' started by MINIz guy, Nov 28, 2010.
  1. MINIz guy
    MINIz guy Two Bucket System Washer
    My dad just came back from HK and brought me 2 Japanese window coatings (polymers?). One, of course, is AmetVi which was talked about in the forum before. Only issue is that they are in Japanese and I can't figure out the directions nor do the pictures help much.
    Second item is this.
    G3 Glass coating, similar to G-Techniq? Anyway, it is comprised of 2 bottles, a compound type thing and a spray. Anybody used this before? I also don't know how to use this since it is completely in Japanese.
  2. kyoshiro
    kyoshiro DB Forum Supporter
    if you can get the instructions scanned or something, i can grab a japanese-enabled friend to read it
  3. Misha
    Misha Nuba Guru
    i can almost say with certainty that its similar to CQuartz product. im sure it some kind of ceramic product that very popular in japan, CQuartz is made in Japan, seen a lot of videos on youtube of products with similar properties
  4. kdude
    kdude Jedi Nuba
    I can read it :) ! It says use the two accompanying geishas to apply as needed !
  5. oldcracker
    oldcracker Jedi Nuba
    from the chinese words that I could read it says it lasts a year!
  6. porta
    porta Jedi Nuba
  7. MINIz guy
    I tried the translator and it is very broken English. Can't make sense of all the numbers.
    I have attached the instructions for both products. Click on them to enlarge them even more.
  8. MINIz guy
    Can anybody help?
  9. CU2MIKE
    CU2MIKE Guest
    I have no clue what the 1st label says.
    But the 2nd label says it's suppose to last 18 months before it completely fails.
    The intruction said to:
    1. Apply the cream looking thing with sponge.
    2. Apply an even coat
    3. Leave to dry
    4. Spray it with the G3 liquid thingamajig
    5. Wipe it off with MF towel
    6. Done!
  10. CU2MIKE
    CU2MIKE Guest
    BTW, I only understand the Chinese words, in step 3 it said to leave it "dry" in Chinese, but in Japanese it could have meant to leave it until it "hazes". Better to confirm step 3 with someone else would speaks/reads Japanese.
  11. kyoshiro
    just fwded the pics to my friend who can read japanese
  12. kyoshiro
    ok from my msn....
    From 40km/h onwards, even if it rains you'll be able to see
    Bugs and crap on your windshield? will fall off
    Step 1: Clean the crap off your glass
    if it's a cold day, use the heat in your car to warm the glass up
    Step 2: Open the thing up
    and take the cover off the filter
    Step 3: Use the filter on the glass
    to use it you have to push the sides of the bottle?
    or something
    you can adjust the position of the handle thing depending on whichever hand you use
    Step 4: When you're done, put it back in its original position and cover it again
    Step 5: Wait 5 minutes, then wipe the glass off with a damp towel
    then wash the towel
    the 2nd one too?
  13. kyoshiro
    and for the other one ...
    1. clean the glass, squeeze the crap out on a cloth (cotton?)
    2. rub the crap all over the glass gently
    then once you're done
    wipe down the glass with a damp or wet towel
    or you can wash the glass
    cap the bottle
    3. use your wipers
    4. open up the spray bottle
    5. the range on the thing is 20x20cm, spray once then use a microfiber cloth to wipe the glass clean
    after
    don't let the glass get wet for 2 hours
    if its too hot, or too cold then wait 24 hours
    okay anything else?
    i'm not responsible if i got it wrong
    though i'm sure i didn't
  14. MINIz guy
    Thanks! Those explanations will do fine!
  15. kyoshiro
    btw those were all MSN copy n pastes so dont blame her if its wrong (and no im not the one to blame either :))
