Is this a decent pressure washer?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by philttz, Apr 11, 2009.
  1. philttz
    philttz Any Rag Vehicle Washer
  2. supercharged
    I think it's not bad. If you are getting gasoline pressure washer, then yes, you want Honda. I was looking at Karcher gasoline with Honda engine. But purchased electric Karcher at local Costco...
  3. philttz
    why Honda?
  4. J BELL
    J BELL Nuba Guru
    I loved my honda engine in my pressure washer, before it got stolen :( Good price
  5. supercharged
    because it works, works, and works...just like Honda cars...not like some - breaks, so out technicians can have a job...sorry, I just had to say that...because I value every dollar I have.
  6. TexasTB
    TexasTB Obsessive Detailer
    yep. Honda motors are great. I have one on my pressure washer that I use daily, for the past 3 years. hasn't let me down yet. The pump on the other hand..... just started going out ....... again.
    I just picked up a new pressure washer from Craigslist..... with a Honda motor of course...
  7. PJS
    PJS Birth of a Detailer
    Specs look decent for the price, but I'd look at something with greater flow and lesser pressure.
  8. milabfocker
    milabfocker Jedi Nuba
    Appears to be a nice unit for the price. However, the following points are worth consideration.
    -The GPM is great; however, most DI units require a flow rate of less than 2 GPM (obviously this is irrelevant if you do not own or do not plan to purchase a DI unit).
    -I believe 2600 PSI may be overkill for most detailing applications. You should ensure the PSI is adjustable if you believe this may be a legitimate concern.
    Hope this helps.
