Iron X
Discussion in 'Car Detailing Product Discussion' started by detaildude3629, Jul 6, 2011.
  1. detaildude3629
    detaildude3629 Birth of a Detailer
    Never used this product before,I have a detail on friday that i will use this product on what is the proper application of this product? thanks guys:applause2:
  2. 911Fanatic
    On the back of the bottle, there is an area called INSTRUCTIONS! LOL If you follow them, you'll be fine. :)
  3. astro_ng
    astro_ng Jedi Nuba
    spray on car, wait till magic happens and you start seeing unicorns...or just purple stuff.
    Rinse off before it has time to dry.
    Good day.
  4. Supertuner
    Supertuner Jedi Nuba
    lol, I always like to check the forums before I use a new product as well
  5. Kilo6_one
    ^^^^ That is awesome LOL............
  6. newbie001
    newbie001 Birth of a Detailer
    Is this (spray on/wait/rinse) correct?
    The carpro website (Iron X) says:
    How to Use
    1. Wash the car or wheels surfaces, make sure surface is in cool temp.
    2. Shake well, spray on the surface,rub it in with damp sponge thoroughly, wait 5 min. while contaminants change its color to purple/red, wipe off with damp soft sponge. IronX can be dried on surface but not under sunshine!!
    3. Rinse well or power wash the whole surface. Car is ready to clay now.
    Are the sponge steps really necessary?
  7. detaildude3629
    Well just wanted to get some input on the way to use the product....sounds like not hard to use,,,by the way its pearl white in color..plan on a 2 stage correction on the paint also...thanks for the information guys...
  8. sal329
    sal329 Nuba Guru
    I have used it 2 ways. 1 wash the vehicle, rinse, spray Iron X while wet let it do its thing then rewash. 2 spray Iron X onto a dry a car before washing wait and let it do its thing then wash as normal
  9. 911Fanatic
    I have washed, applied, let soak and pressure washed off and I have washed, applied, let soak and rewashed. Works well either way.
  10. newbie001
    So no need to rub in with damp sponge or wipe off? Just wash, apply and rinse off (or apply and then wash as normal)?
  11. 911Fanatic
    I have rinsed with a hose or pressure washer and both seem to rinse the Iron X off cleanly. I believe it says to wipe down with a damp towel to possibly remove stubborn deposits.
  12. newbie001
  13. Supertuner
