Ioncoat Naviwax Review
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by domino, Oct 3, 2010.
  1. domino
    domino Welcome to Detailing
    Now im not a sealant man, and as good as the Amigo + PowerLock looked after a wash, i just had to layer a carnauba
    Thinking about what to test next, i decided on my Ioncoat Naviwax
    For those that dont know, this is a premium Japanese wax that is getting some attention from the UK detailing folk. I bought it off ebay UK for around AUD $60 bucks landed - which isnt alot considering you get about the same amount of wax as FK1000
    The tin is huge! Though it is somewhat deceiving as enclosed within is its own sponge applicator. Directions are to dampen the sponge app and WOWO. Initially the sponge app felt a bit coarse, but did soften in water and proved to work perfectly with this wax
    Note! All pics are off my iphone and are completely unedited. I was so impressed with the finish, i decided to take crappy iphone pics to show just how good it looks.... if that makes sense
    Ok so time to prep the pad. Dampen and rotate 2 times in the tub. This is definitely not a fragrance'd wax, those who are familiar with Colly waxes will recognise the carnauba/chemical odour. Its not over powering like 476S feels at times, but is there with you throughout the detail
    By dampening the pad, the wax does spread very far, though you cant go any further than one panel at a time before the pad dries out and starts to grip the paint. On the rear quarters i split them in two along the body crease line. Ring the pad out in a bucket of water and keep going. Total time taken was around 25 mins
    Wiping the wax off reminds me of RBOE. The mf grips on initial swipe, but then it's carnauba business as usual. Not quite one swipe Lusso/Vic Red/Blackfire MS easy, but nowhere near as fussy as the Colly waxes in terms of having to worry about applying thin or leaving it on the paint too long
    The finish left behind is very impressive. For some reason i was expecting a 476S/915 style finish (mainly due to the smell, price and durability claims) but this far exceeds them
    It has definitely added that carnauba depth the PowerLock was lacking and hasnt appeared to mute it's high clarity/reflections at all. This particular version of Naviwax is deigned for dark colours, and it shows in the depth it has added - and does prove you dont need a heavy montan tinted wax to achieve a deep black finish (ie; my Crystal Noir testing)
    Driving home on a very sunny day, the wax feels like it has done a zymol trick and melted into the paint. The gloss is definitely improved and there is a deep black liquid shimmer over the paint i havent seen since applying Lusso Oro over CK RMG/VMG
    Pics are immediately after app. On reading this wax's sheeting party trick, i wet one panel and was blown away, the sheeting is the best ive ever seen, im talking literally a dry panel. Next wash ill have to video it and update this thread then
    .......a JDM wax for a JDM car
  2. 911Fanatic
    Looks nice Sam. Maybe get some pics with a good camera as well. :)
  3. Reflect
    Beading pictures?
  4. jjl
    jjl Birth of a Detailer
    Can't wait for the update on beading. Do you know what the durability is on this wax? I have always wanted to try some waxes or products from Japanese manufacturers.
    Btw, is that a pakshak ultra plush mf?
  5. domino
    ^yep micropak ultra-plush - i used to be the Aus distributor
    durability is meant to be Collinite good according to the UK guys who have been testing it. I'm actually going to test this wax properly this time, rather than be quick to remove it and try another cleaner/wax combo. Im just thinking whether i should add another layer, as when i have tested waxes in the past, it's always been after 2 layers
    Ken, i was thinking about another photo session, but then every LSP looks good when taking digicam pics.....the iphone never lies. I might take some digicam pics say a month after app to show how it's holding up
    beading/sheeting pics and vid next wash
  6. Misha
    Misha Nuba Guru
    pretty nice, would be interesting comparison with other waxes but then again its not gona be huge difference,
    did quick search on ebay and looks like there are two versions, for light and dark colors
  7. domino
    update!!
    ive been testing durability of this one coat of naviwax for 7 weeks now and its still going very strong
    ive washed the car 4 times since application, and left the car for 3 weeks without washing during which we had record spring rainfall followed by scorching aussie sun
    there are absolutely no water spots on the paint and the finish still looks as good as the day i applied it. Im very impressed with this wax, and has to be the only wax ive used so far that hasnt left water spots under our harsh aussie sun
    beading /sheeting is only slightly down compared to the first wash but still better than most waxes fresh out of the tub
    now the vids as promised... i used my iphone4 and not sure why the vid is so narrow
    beading - hosing off pre-wash DP Xtreme Foam in WG Foam Gun
    sheeting - after washing with lusso oro shampoo
    drying - wet mf wiped across the panel shows no water spots at all
    finish - dried with CG miracle. No QD used here, this is straight after washing with lusso oro shampoo
  8. kyoshiro
    kyoshiro DB Forum Supporter
    Mmmm I really should look into this if I go to japan for vacation again (And go back to Hk in may)
    Just need to first figure out where do they sellem in japan ( or I guess I can ask my friend in japan to look it up )
    Is it catered to Japanese paint work?
  9. domino
    i dont really believe in paint specific waxes (polishes yes), but id imagine during development they'd have tested it on japanese cars more than anything else
    you can buy it off ebay uk, the seller ships international
  10. kyoshiro
    well if i got to japan for vacation, i can always stock em up in my suitcase =p
    having said that, if i do find em, i probably could smuggle a few into NA and maybe send a few from Hong Kong.
    we'll have to see in may and see if i enter the unemployment ring or not
  11. Dannyk
    Dannyk Jedi Nuba
    Very impressive shots and results. Like yourself using powerlock, cannot resist the urge to follow up with a wax, which in my case has dramatically changed the appearance of the cars i have tried it on. Using 476s by the way.
  12. Nokiemon
    Nokiemon Virgin Detailer
    I have been a member of this forum for over a year but do not post, just read the great information and member expertise. Really like this site for my go-to information and product feedback. Been into detailing for over 20 years, long before it grew into the hobby it is now. Love the new products and technologies that have impacted and improved this industry sector over the years.
    However, I am the US rep for Naviwax and we are trying to get it over here to the states in the near future through some of the great vendors we have available to us. It is really new to the market so we are working on distribution as we speak.
  13. Misha
    Misha Nuba Guru
    looks great, but i found one thing about this car that i dont like.... Orange peel, i knew car wasnt perfect lol
    hows durability?
  14. domino
    yeh the peel is quite apparent given its solid black, especially in full sun pics
    nowhere near as bad a new BMW though lol
    i dont think there is enough clear coat on the car to wet sand and continue my frequent correction/product testing
    durability on this naviwax is extremely impressive. Ive only ever seen Z2/Z5-Pro hold onto it's looks this long
    people arent giving this wax enough credit imo. It's showing all the durability everyone loves in the colly waxes, but without the tricky app and MUCH better looks
  15. Domman56
    Domman56 Birth of a Detailer
    is it just the pics or does that car have a ton of orangepeel
  16. Danny
    Danny Nuba Guru
    Domino how much does it go for and where did you order it from?
  17. domino
    i bought it for around AUD $60 landed, and our dollar is pretty much at parity with the ever decreasing US dollar now
    cheapest place i found it was ebay uk
  18. Danny
    Danny Nuba Guru
    Thanks I guess I will try and wait until it makes it to the states thats if it ever does. I'll just have to keep googling online.
  19. Mike Murphy
    Mike Murphy Any Rag Vehicle Washer
    Hey Domino, when you record a vid with a smart phone you have to turn it sideways while recording so it will display as a widescreen video.
  20. GDAL
    GDAL Guest
    Thanks for the review Domino. I actually contacted the UK ebay vendor that is selling the wax and shipping for the wax bundle (both dark and light color tins) is about 30 sterling pounds to Virginia. It's about 145 US dollars for both tins shipped which is not a bad deal, but I can't afford (or need) these new waxes right now.
    I'll wait until they are sold in the US.
