Hey everyone! A buddy of mine and I just finished installing 20mm Ichiba bolt on spacers on my rear wheels. I have 15mm stud replacement H&Rs to go on the front, but I need to get extended studs. If you know where I can pick up some extended studs for a 15mm spacer...let me know. Anyways...on to the before and after pictures: Before: After: This install was very easy...40 minutes max for both wheels. Spacer bolts and lug nuts were torqued to 85lbs and I'll be going back to my friend's place on Tuesday to retorque the lugs and make sure everything is still nice and tight. I drove the 17 miles home and didn't have any issues...hopefully it stays that way. Thanks for looking!!
look for ARP studs i guess. wheel shops should have them too i guess http://ignitoperformance.com/wheels_tires/lugs_nuts_wheel_studs/c-10119.aspx
Thanks for the compliments guys!! I can't wait to get the fronts installed...and then of course give it a nice detail.
