Hydra Flexi Blade
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by run115, Nov 19, 2009.
  1. run115
    run115 Any Rag Vehicle Washer
    I found in my garage an Autoglym Hydra Flexi blade that i bought ages ago but never used, do you think it is a good tool/aid to dry the car or should I stay away from it?
    Vince
  2. willjco
    willjco DB Forum Supporter
    I personally don't like blades for drying cars because if one peice of dirt gets on it it will damage the whole paint job.
  3. agpatel
    agpatel OD On Detailing
    ekkk...please don't use it on the paint...one spec of dirt can kill the finish. I will say that they are great on glass to dry them off!
    Using the open ended hose method I find that there is almost no water left on the car and the little there is I just wipe up with a MF.
  4. kc1337
    kc1337 Obsessive Detailer
    That method only works on a lsp covered car
  5. agpatel
    This is true, or a clayed car or polished. Leaf blower works well on non-smooth finishes as well, and helps dry off the wheels/tires pretty fast and grills, also around gas doors and what not.
    Bottom line, dont use a blade, get yourself a nice WW or MF drying towel.
  6. run115
    Ok, thanks guys, will give it to the missus for the house glass then.
  7. Misha
    Misha Nuba Guru
