husky pressure washer
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by nyrep1, Mar 25, 2010.
  1. nyrep1
    nyrep1 Obsessive Detailer
  2. I VIK I
    I VIK I Two Bucket System Washer
    What foam lance/cannon would fit on that. Ive got something like that and Ive been wondering.
  3. nyrep1
  4. Duratys
    Duratys Welcome to Detailing
    I would try to get one that has over 2.0gpm. PSI isnt as important as GPM.
  5. 911Fanatic
    I picke up a 1500psi / 1.5gpm at Home Depot because they had them on for $50. Thats right, $50! HOW BAD COULD IT BE. Other than the POS plastic hose it came with and the crappy wand, its been a good little machine. Need to swap out the hose and wand soon so I can use my foam cannon with it. Haven't had any jobs I couldn't do with it. There have been times when a little more power ( GPM ) would have been nice but for $50, well worth it.
  6. richguy66
    richguy66 DB Forum Supporter
    I wanted to buy the same pressure washer as well. I'm totally lost when it comes to pressure washers so I wouldn't know what else to buy. All I know is that I need a foam cannon or lance (I have no idea what the difference is) and some sort of adapter.
  7. vtec92civic
    vtec92civic Nuba Guru
    i personally would go with the briggs and stratton one as they make most the motors on the pressure washers at such places like home depot and sears and lowes as well.
    Looks like a nice machine i just hate that everything is plastic.
    Most foam cannons are universal it's just some of the fittings that need to be changed out that's all.
  8. richguy66
    By any chance would you know what particular fitting is needed for the Briggs PW?
  9. vtec92civic
    you would need to see the actual gun from the machine. There are so many different fittings it will all depend on the gun.
    Here are a few:
  10. Esienmann_M6
    Esienmann_M6 Two Bucket System Washer
    Especially true when using a CR Spotless unit. there is no reason for automotive use
    to get anything above 1.5gmp
  11. Frankastic
    im too looking for a cheap PW, cam spray 1500A is just too much for me.
  12. racersky
    racersky Jedi Nuba
    I just returned mine. My pressure washer blew the hell up from the wand. All the O-rings were destroyed. I'm trying to find a gas powered one and found the Homelite one but it's no where to be found on the shelves.
  13. Bunky
    Bunky Guest
    The cam spray seems to need its own breaker too...It can suck a lot of power.
  14. rwisejr
    rwisejr DB Forum Supporter
    That has never been a issue
