Hows this pressure washer for a weekend warrior?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by stingray23, Mar 31, 2011.
  1. stingray23
    stingray23 Jedi Nuba
  2. astro_ng
    astro_ng Jedi Nuba
  3. stingray23
  4. Danny
    Danny Nuba Guru
  5. supercharged
    Pressure washer is something you will be using every time you wash your car. So, you have a few options - buy a cheap one and replace it every couple of years, or spend an extra buck on a durable one. I learned my lesson the hard way, and must admit, whatever you do, don't buy a cheap Karcher. PW you posted - I don't have ANY experience with, so I cannot comment. But if your budget allows you - get Cam Spray 1500A from Phil (detailersdomain), you will be glad you did. Remember - you get what you pay for...
  6. sal329
    sal329 Nuba Guru
    I was looking at the 383 but can not find a foam cannon to use with it. I still may get one.
  7. 911Fanatic
    The pressure washer you are looking at will get the job done no problem. As Supercharged said, spending a little more will be a better choice in the long run. The AR 610 is very similar to the Camspray unit, flows 2.1 gpm and can be had for $499 online.
  8. mrgolfrider
    Is the AR 610 a 15 amp unit or 20?
    Sent from my HTC Vision using Tapatalk
  9. stingray23
    Thanks guys
  10. co78
    co78 DB Forum Supporter
    I have the AR383 unit, it works well but I have only used it once. I am in the process of finding a matching fitting so I can use a foam cannon. Looks like the lavor fitting is the closest one.
  11. Kaban
    Kaban Welcome to Detailing
    I was going to buy a Karcher, but I'm just going to hold back until I can afford a cam spray 1500
  12. Chaseme
    Chaseme DB Forum Supporter
    Without any prior knowledge. Any reviews I read are generally NOT automotive application related. I think most negative reviews are from ppl expecting these units to strip down their decks. That would probably be asking too much out of a budget consumer PW.
  13. Kilo6_one
    im still shoping as well, thanks for that link it looks like a nice unit............. having a hose reel is a plus.
  14. stingray23
    You can't connect a foam gun to this?
  15. kyoshiro
    kyoshiro DB Forum Supporter
    theres no official tips for it as far as i know (im also usually wrong) but im sure you can prob retro fit something on...
  16. 911Fanatic
    Its a 15A. Here's a link for you. AR610
  17. kakeuter
    kakeuter DB Forum Supporter
    I have the AR610 and it is incredible! I can hardly hear the unit when it's on, it's fully adjustable and my foam cannon hooked right up to. However, if you cannot swing the $489 pricetag, then this unit might siffice. I think AR North America makes great pressure washers. Good luck with the purchase.
    -Kody-
  18. GDAL
    GDAL Super Moderator
    Thanks for the info Kody ... have you used it for vinyl siding? I wouldn't mind buying it, but $499 for a dedicated detailing pressure washer isn't cost effective for me.
  19. stingray23
    I'm sure it is nice, but $489 is a lot more then I'm looking to spend right now. I think I'm gonna give the AR383 a try.
  20. mrgolfrider
    I wonder how the AR118 performs. It is a price I could afford.
