How to use P21S TAW as a pre-wax cleaner?
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by domino, Dec 16, 2010.
  1. domino
    domino Welcome to Detailing
    Hi guys
    I intend on buying some TAW from our local supplier
    I read it can be used to remove wax as a pre-wash, but how exactly do i use it?
    It comes in a spray bottle, so do i just trigger down the entire body, dwell and rinse off? Or do i need to rub it across the panel with a damp MF?
    Will it work in a foam gun? If so, what kind of ratio to water?
  2. DaytonaJae
    DaytonaJae Birth of a Detailer
    I have used the TAW as a LSP Stripper before. I found from personal experience that it works best if you just treat it as a car wash shampoo when you want to remove the LSP. I don't think there's a need to actually wash your car with a shampoo after the TAW. Since the TAW is sort of expensive, I try to get more out of it by diluting it 1:1.
    What I did was rinse down the car, then sprayed the TAW over the whole car, let it sit for a minute, then agitate it with a soaked wash mitt, then rinse off.
    Since I ran out, I've tried Dawn dish detergent, and it seems to remove the LSPs nicely as well. From a foam gun its nuts how much foam there is. I never tried TAW from a foam gun yet.
    I change my mind a lot about LSPs and am still learning which combination of products works for me, so I strip off and start over a lot.
    I just got a gallon of Adam's APC, which costs a lot less, so I am hoping it works as well in removing the LSPs as the P21s did.
  3. EbbeJ
    EbbeJ Jedi Nuba
    Yes, it will work through a foam lance too. I tend to put 2 inches of TAW in a 1 liter bottle and fill it with water, problem is that it foams too much when using an foam lance.
    Normally I spray the entire vehicle with TAW(hand kwazar sprayer), let it sit for a while and then pressure wash off.
    You can also mix it in your bucket-wash solution(can't remember the correct dilution ratio, try looking at the bottle, but make it strong). I like adding a little shampoo to help with lubricity.
    Kind regards,
    Ebbe
  4. billyblooshoes
    Most people either use it in their foam solutions then hand wash. Or you can pressure rinse the car first, spray down the entire car with TAW, let it dwell, then rinse off and wash.
  5. evolutionwc3
    evolutionwc3 Any Rag Vehicle Washer
    I’ll agree with what’s been stated already. I’ve used P21s TAW in the foam cannon and in the wash bucket and both methods worked equally well. It’s a great product.
  6. domino
    thanks for the help guys
    ill pre-soak with it in the foam gun, then add a little to my dawn wash bucket
    it wont damage door/window rubbers will it?
  7. 911Fanatic
    It shouldn't Sam. I have a citrus cleaner here that is waaaay stronger than TAW and haven't had any issues with it staining anything.
  8. CG6Lemon
    CG6Lemon New Member
    well this is how i do it. First i spray down the whole car to loosen up the dirt. Then i have the TAW diluted 4:1 and i spray each panel and let it sit for one to two mins. Afterwards i hose it off and work on the next section so i can time it carefully. one thing to keep in mind is that do not let it dry. so hose is a bit to keep it wet.
  9. detaildude3629
    detaildude3629 Birth of a Detailer
    What is the name of the citrus cleaner you talking about Ken?:chitchat:
  10. Kilo6_one
    Ive been using Dawn, its so much more cost effective........... any disadvantages to doing that? I put it in my foam gun, spray and let it dwell, then wash it off.
  11. Dust2Glory
    Dust2Glory Nuba Guru
    I use Zep Citrus.... a lot cheaper then TAW and multi-use for wheels, tires, wells, jambs, carpets
  12. Emile
    Emile Welcome to Detailing
    The poor man's P21S TAW !!!
  13. dsms
    dsms DB Forum Supporter
    TAW is a very good product because IMO its a little more clingy than your average APC which runs faster but it is very expensive and for the purpose of stripping old wax their are far more cost effective ways to do this.... all of which have been explained ad nauseum so I wont say them again (cough cough IPA)
    From my experience TAW pre-soaks wont do anything to harm paint or trim regardless of how delicate. I cannot same the same for all APC's .... some people are cool with using APC at 3:1 but I personally feel that way to strong for some cars so I usually go 5:1 or 6:1 just to be safe. On your car being finicky black GT-R paint I would not take a chance so use be careful what you use but I think TAW would be fine.
  14. Trents_goat5.7
    Trents_goat5.7 Jedi Nuba
    Nothing wrong with that lol. I do the same.
  15. Kilo6_one
    I got some megs APC.... diluted is it ok for paint? Like lower rockers and such? Or should I get some ZEPS too? never hurts to have a wide range, but just curious
  16. Bunky
    Bunky Guest
    Optimum is considered paint safe.
  17. domino
    Yep exactly, it took me a few tries to work out the best concentration of IPA, started with 50% IPA and the paint hazed over and i shit myself
    ended up settling on around 15% and that seems to work fine
    and for this reason i dont mind spending the extra money on TAW if i know its perfectly safe
