How to use Menzerna on new vehicle
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by zrex, Jul 14, 2010.
  1. zrex
    zrex Virgin Detailer
    I've had my 2010 Audi S5 in Brilliant Black for a month now. Its outside mostly except for (Toronto) winters.
    The Dealer detailed it. Thankfully no swirls.
    I plan on using Dawn to wash the car then clay bar it.
    After reading many posts I'd like to try Menzerna's products to protect the vehicle.
    I also plan on purchasing the PC polisher.
    I am having trouble figure out which Menzerna products I should purchase and what kind of pads I should use.
    I am thinking Power Gloss/Power Finish/Super Finish.
    Anyone have experience/suggestions as to how I should go about detailing?
    Thanks.
  2. Dust2Glory
    Dust2Glory Nuba Guru
    if it's brand new with no swirls, powergloss is WAY out of question! You'll damage the paint even more!!
    If there are minimal swirls, I would go with Powerfinish/green pad
    then a finishing polish and black pad
  3. zrex
    Thanks for the info Dust2Glory. I just notice the Power Gloss has a 4.5 cut!
    No real swirls yet.
    I'd just like to protect the finish and make it shine.
    Are these finishing products it or do I then need to wax?
  4. lebreeze
    lebreeze Any Rag Vehicle Washer
    You need to seal or wax it or both after you polsih.
  5. Ditto ^ I would use 85rd for the finishibg polish :cig:
  6. zrex
    Any wax/sealant recommendations ?
  7. Darkstar752
    Darkstar752 Horizon Detailing
    Powerlock for a sealant IMO.
    Just to clarify, polishes don't protect the paint at all, all they do is cut down and level the paint. Power finish and Final finish should be all you need, then a wax or sealant of your choice. Sealants will leave a glossier, brighter look, and waxes typically leave a deeper, darker finish.
  8. Dust2Glory
    Yes, powerlock for your sealant... then you can really choose any wax you want for your paint.
    For even longer durability I would top Powerlock with Collinite 845IW
  9. P1et
    If you don't have swirls, then 85RD on some of Detailer's Domain's pads would be enough. One of my favorite combos is 85RD on a blue DD pad.
    If you have a little bit of swirls, then you can step up to Power Finish. Which is a great product, by the way.
  10. I am sprung on Power Finish. Does anyone know of a good 12 step program :help:
    Kind Regards,
    Lindsay Lohan
  11. metajames
    metajames Birth of a Detailer
    +1 for 85rd + powerlock
  12. Legacy99
    Legacy99 Wax on..Wax off
    Yes, AAA has one
  13. togwt
    Sorry Lindsay, but as others before you have learned to their cost, fame doesn't put you above the law.:shrug:
    We'd gladly recommend a 12-step program but you are such a clebrity you'd feel it beneth you to attend :worship2:
  14. togwt
    +2 for 85rd + powerlock
  15. zrex
    Thanks for all the great advice.
  16. Your absolutely right. I'm am way better then you mere mortals. My turds are more valuble then Crystal Rock :hmph:
    Kind Regards,
    Paris Hilton :flirt:
    P.S. 12 step program??? I don't need no stinking 12 step program. All I need is a stiff drink :drinking2:
  17. porta
    porta Jedi Nuba
    I would use PO106FA Super finish, on a soft polishing pad.
  18. metsfan
    metsfan Birth of a Detailer
    why polish if there are no swirls and was just detailed . Why not just use a cleaner sealant and wax
  19. porta
    porta Jedi Nuba
    To get the best gloss.
  20. BobbyG
    BobbyG Virgin Detailer
    Wash it throughly and clay as stated. Bring so new and knowing Audi the finish should be presteen at this point.
    I like and prefer Menzerna products and you shouldn't require anything more aggressive than PO85RD and use either a gray or blue Lake County or comparable pad.
    Shake well and apply a circle around the perimeter of the pad. Set the speed to 3 and place the pad on the surface and sort of spread it around then turn it on. Once a nice even coat on a 2' X 2' area is achieved then bump the speed up to 5 and work the polish in.
    Once satisfied, clean the surface and apply your favorite sealant and or wax for ultimate gloss and protection, Powerlock is a good choice. You can apply these by had or use a red pad which is what I prefer.
