how to remove pinstrips?
Discussion in 'Car Detailing Product Discussion' started by DetailAddict, Aug 15, 2008.
  1. DetailAddict
    DetailAddict Two Bucket System Washer
    so i have the 4runner with pinstrips and want to remove them... I know heat gun would do the trick. but is there anything else I should know or try to speed up the process? It's going to take FOREVER for heat gun alone! :(
    Leo
  2. yukonon22
    yukonon22 Wax on..Wax off
    Arnt pinstripes a paint?
  3. DetailAddict
    these are the one they stick onto the paint surface...
  4. shiny
    shiny Jedi Nuba
    Can't you just peel them off? I had a car many years ago and I was able to remove them by peeling them off. Then polished the surface to cleanup. Did notice a a little difference in colour though after it was removed.
  5. yukonon22
    Maybe just a blow dryer and peel them like shiny said. Finish off with some goo off and polish it up.
  6. DetailAddict
    this car is like a 98 or something... the pinstrips are ON the car... :( So far heat gun is the best way, but I want something faster... even with heat gun, it breaks every 1/4 inch or so... So it's not like I can pickup one end and pull it off all the way down... :(
  7. DetailAddict
    yeah, that's what I tired, heat gun (same as blow dryer)... just taking too long... the pinstrips are too old... :(
  8. yukonon22
    best i can do
  9. shiny
    shiny Jedi Nuba
    Will a plastic scraper help?
  10. DetailAddict
    i am afraid that would scratch the hell out of the paint... :(
  11. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Use platic razors blades, works everytime
  12. DetailAddict
    where do I find those?
  13. Asphalt Rocket
    Any autoparts store or a better choice would be a autobody supply store. If that doesn't help I believe topoftheline.com has them.
  14. DetailAddict
    sweet! thanks! I haven't ordered from topoftheline.com for a while since I've ordering from DD. :D thanks again!
    Leo
  15. bryansbestwax
    3m pinstripewheel
  16. DetailAddict
    interesting... wonder if i can get it from a local store...
  17. Grey Ghost
    Grey Ghost Jedi Nuba
    the problem with the vinyl pinstripes is the moment they are exposed to the heat from the sun they immediately dry out and turn very brittle. which is why you see them break every 1/4 inch.
    the only SAFE way you'll get it off is if you use a heat gun and a plastic scraper and a lot of patience.... if you find it somewhat difficult to remove/lift the next piece, a razor blade at one corner and slide just enough under to get a finger to grab and LIFT, it will do the trick just nicely; but be sure not to move against the paint because the heat gun can soften it up and you could make some damage
  18. DetailAddict
    unless i can find that wheel at a local store... looks like i just have to take my time... :(
    thanks all!
  19. Asphalt Rocket
    If you can not find the wheel get the plastic razor blades, they will not damage the paint when used against it.
  20. bryansbestwax
    I suggest the scraperite blades.
