How to Maintain your Foaming Lance
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by 911Fanatic, Dec 6, 2009.
  1. 911Fanatic
    Figured this would come in handy given all of you buying these things. Did mine yesterday and it only took 10-15 minutes.
    How to maintain your foaming lance - here
  2. GDAL
    GDAL Guest
    Thanks for the info Ken. I don't have one yet, but it's on my wish list.
    guys, I know all of us are pretty mechanically inclined here, but I'm just throwing this out there 'cause I have a seen a lot of damaged equipment when people use red loctite on stuff that really doesn't need it ... use blue loctice!!!
  3. Misha
    Misha Nuba Guru
    good info. any preventative maintenance so we wouldnt have to take it apart?
    im sure you can use that white tape thing that they use for pipes, forgot the name but im sure blue will work better
  4. BigAl3
    BigAl3 Birth of a Detailer
    with both the foam gun and cannon, after each use i fill it up with water and run it through so it releases any soap/residue that may be left inside to prevent it from being clogged up. it's worked well for me...
  5. richy
    That's a great idea..prolly even better to do it with hot water,eh?
