How to get gum out of carpets.
Discussion in 'Interior Car Care' started by my04lincoln, Jul 4, 2008.
  1. my04lincoln
    my04lincoln Two Bucket System Washer
    What does everybody use to get some gum out of carpet?
  2. FMINUS
    FMINUS DB Pro Supporter
  3. Denzil
    Oooh, I'll have to pick some of that up. I totally forgot about gum-stuck-to-carpet/mats situations.
  4. my04lincoln
  5. Showroom Shine
    Showroom Shine Birth of a Detailer
    This is what I have found to work best. Put some ice in a baggie. Use it to freeze the gum. Then most of it can be picked or scrapped off with a plastic knife. A little hair spray dabbed on it should remove what is left!
  6. budman3
    budman3 Birth of a Detailer
    What he said, I've only had to use this technique once but it works :headbang:
  7. eShine
    eShine Guest
    I use my nitrous bottle. 1 second squirt and the gum snaps off in pieces.
  8. sly
    sly Birth of a Detailer
    The easy way for me is use ice stick to the gum (to make it stiff) then you can remove it.:thumb:
  9. detaildoc
    detaildoc Guest
  10. JohnyB
    JohnyB Birth of a Detailer
    Spray can of air held upside down when spraying will have the same effect.
  11. Duratys
    Duratys Welcome to Detailing
    A nitrous bottle takes the garage party to the next level.....oh man the stories :thud: :applause2:
  12. Denzil
    Yeah you're right, I totally forgot about this. I assume the cans of air are cheaper right?
  13. jayjacque
    jayjacque Any Rag Vehicle Washer
    Nitrous= "Compressed Air"?
  14. JohnyB
    Usely i can find them as low as 5-6 bucks. :shrug:
  15. 911Fanatic
    Autoglym Intensive Tar Remover. Spray on, wait about 20 seconds and rub with a MF. Usually works for me.
