How To Fix This?
Discussion in 'Interior Car Care' started by Street Wolf, Jan 6, 2011.
  1. Street Wolf
    Street Wolf Any Rag Vehicle Washer
    How would I go about fixing this? It's just grime buildup from over the years. I'm not sure what the fabric is, but perhaps someone on here can tell me by looking at it?
    What method, tools, and products will I need to use?
  2. Perfections
    Theres a ton of solutions but start with something simple like folex, you can find that at home depot.
  3. Emile
    Emile Welcome to Detailing
    You can use a carpet/upholstery cleaner if you already have one on hand. CG Grime Reaper 5:1 would work great on this as well.
  4. cnut
    cnut Guest
    Zep citrus degreaser 10:1 and see what it does. It's available at home depot.
  5. billyblooshoes
    folex straight, or some kind of APC 10:1 with a brush to agitate would be what i would do. zep citrus 10:1 would probably be good as well.
  6. Street Wolf
    Thanks guys. I'll swing by Home Depot tomorrow and grab what I need.
  7. richy
    Duragloss foaming interior cleaner and lots of white terry towels. Folex is also a good idea. Krud Kutter would work too. The white terry's are important, they will absorb the stain.
  8. Chas
    Chas DB Forum Supporter
    I have always had good luck using Tuff Stuff on stains and dirt build up like this.
  9. christian900se
    I have to put another vote in for Folex undiluted. You will need to reapply and agitate a couple of times since that stain looks quite embedded into the fabric.
  10. Danny
    Danny Nuba Guru
    Simple Green at 1:10 also horse hairs brush to agitate the fabric and some towels to soak up and remove the grime. Tuff stuff also works good just let it sit for a bit then agitate the area and soak it up, you will have to go over it a couple of times before you can get it out.
  11. togwt
    I would recommend that you first identify the material and then select a suitable cleaner.
    What is the vehicle make? Could this be Alacantra?
  12. pektel
    pektel DB Forum Supporter
    I'm guessing a Ford with cloth interior. But that's just my guess.
    I suppose it could be an old lexus/toyota too.
  13. Dubbin1
    Dubbin1 Jedi Nuba
    Folex, its cheap works great and can be found at Lowes.
  14. Trents_goat5.7
    Trents_goat5.7 Jedi Nuba
    I'm betting it's his Land Rover Discovery.
  15. Street Wolf
    Thats right, it's a 2000 Land Rover Discovery.
  16. nnjmike
    nnjmike Virgin Detailer
    Just read this and wondering what actually worked!?!? Did it ever come out?
