how to eliminate those darn RIDS!!!!
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by ampbmw, May 19, 2008.
  1. ampbmw
    ampbmw DB Forum Supporter
    all I have access to is Menzerna Power Gloss Compound and yellow pad on rotary (so thats as aggressive as I can get)
    this M5 I'm doing is giving me fits with the RIDS and they aren't budging!
    anyone got suggestions as what process might help me tomarrow?
    i got all the swirls out just random RIDS that are bein a pain!
  2. Mindflux
    Mindflux Welcome to Detailing
    You are going to need a stronger polish. Power Gloss isn't as 'power'ful as you'd like to believe.
  3. jake_b
    jake_b Obsessive Detailer
    have you tried wetsanding? it's the last resort.. rather than taking away a lot of necessary cc or paint. it's really effective, if the rds has not gone through the base coat or primer.
    good luck.
  4. reefer_bob
    reefer_bob Obsessive Detailer
    Is it really worth ripping off that much clear coat to get them out?
    Just a thought... :)
  5. Asphalt Rocket
    Asphalt Rocket Nuba Guru
    Try using powergloss with a wool pad, I have gooten alot of correction out powergloss that way but it gets very dusty. As far as powergloss not being very "power"ful, its obvious someone doesn't know how to use it. I will see if Dan(D&D) will post pics of the Audi I did for him with powergloss and wool that took out steel wool marks his customer used to clean berry stains from the paint.
  6. blk45
    blk45 Jedi Nuba
    :yikes: What the hell was he thinking?
  7. Nica
    :nod: I would have to agree with Asphalt Rocket, Meznerna Power Gloss with a wool pad will level out any kind of swirls/scratches/RIDS. One thing to note though is that I personaly haven't mastered the wool pad just yet so I always follow up with at least one more step (with a foam pad) after doing some major corection with a wool pad. I know some members can finish up close to LSP with a wool pad but I'm just not there yet...but hopefully a few more years with wool pad and I might get there...I hope :beg:
    Oh another thing is that reefer_bob bring up a going point, you may want to check to see how much clear coat your removing to remove the RIDS...I mean you can only cut so much clear coat but then again it all depends on each persons style of polishing..any who just my :2cents:
  8. FMINUS
    FMINUS DB Pro Supporter
    Can you come down and help me with my car? :applause2:
  9. Usjdmtuner
    Usjdmtuner Wax on..Wax off
    Ive tried Powergloss with foam pad and it wasnt a good combo..i would have to agree using wool pad would produce better result...ill have to stock up on wool pads..
  10. Asphalt Rocket
    Anytime Phil, just let me know.
  11. Nica
    Lucky you :fs: I wish I could play too :shakehead: :shakehead:
