How much water does a typical detail use?
Discussion in 'Tools - Machine Polishers, Pressure Washers, Detai' started by sikedsyko, Jan 31, 2012.
  1. sikedsyko
    sikedsyko DB Forum Supporter
    I'm looking into getting a tank to provide my own water for going mobile.
    Can anyone ballpark me some numbers on what size tank I should get?
    Typical wash includes: Pressure rinse, Soak with Gilmour Foam gun, two 5 gallon bucket wash method, and a rinse.
    Or perhaps what size tank do some of you use, that could do 2 cars on one fill up?
  2. 911Fanatic
    Your pressure washer will determine how big a tank you will need. Most small electrics will flow 1.4 - 1.9gpm. From there you can figure out how much time it takes to do a pre rinse, wash and final rinse and that will tell you how much water you'll need per vehicle.
  3. sikedsyko
    Thanks further info. I see lots of 125 gallon and 275 gallon tanks on craigslist for cheap. Think a 125 will get the job done?
  4. morgan_w
    morgan_w Virgin Detailer
    ya 125 gallons is plenty.
    Mine is about 70 and depending on the size of the cars I can sometimes squeeze out 2 full details. I use an electric pressure washer (kranzle 1120t).
    I tend to use a lot of water also...ie: Pre-rinse, foam, rinse, wash, iron-x, rinse iron-x, foam again and a final rinse. Then after paint correction is finished I will wash again.
