I used OC on my wrx and have some left over in the syringe. After opening how long is the remaining opti coat good for? Also, after reading several posts it looks like my one panel did not bond properly. Do I need to use optimum polish II and then reapply? Thanks for any help!
Does it look hazy? could be residual oils left or just a high spot applied to thickly. Yeah the OPII should be good then wipe down with damp MF then reapply. As for storage, make sure to push out as much air as you can, then tightly screw the cover and store in a cool dark place and it should be good for a pretty long time.
