How long b4 i could top a sealant with a wax???
Discussion in 'Last Steps: Waxes, Sealants, and Coatings' started by LAV86, Aug 12, 2010.
  1. LAV86
    LAV86 Two Bucket System Washer
    Hi guys..i wanna seal my car with menzerna power lock sealent and then wax it..how long do i have to wait b4 i could wax the car after i sealed it?????
  2. CU2MIKE
    CU2MIKE Guest
    It depends, some people wait 8 hours, some wait 12 hours, I've talked to another detailer who wait a full 24 hours. So it is really up to you (or if the time permits).
    I personally wait 12 hours before applying wax.
  3. Furious_G
    Furious_G Virgin Detailer
    Complete noob question here; what happens if you just put the wax straight on without waiting?
  4. slanguage
    Well, it will probably remove it. Due to the fact the sealant might not be completely "dry" or "cured", it didn't have ample time to bond to the paint. So whatever didn't bond quickly enough would just be removed or moved when applying the wax.
  5. slanguage
    On a side note, I think with Werkstat AJT, you only need to wait 30 minutes, but don't quote me on that.
  6. Reflect
    I think that's the case too.
  7. CU2MIKE
    CU2MIKE Guest
    nice, thanks for the heads up. Will try that out after i finish my bottle of powerlock.
    How's the durability on Werkstat? Any insights will be great, thank you!
  8. Reflect
    I think it's like 2-3 months alone, maybe another month if you prep first with Prime (or any of its derivatives like Strong, Acrylic...).
  9. CU2MIKE
    CU2MIKE Guest
    I see, thank you! I will be sure to try it out next. Always open to try out other products!
  10. metajames
    metajames Birth of a Detailer
    For what it's worth Menzerna recommends 3 hours between applications of powerlock. Not sure if this rule applies to waxes also.
