Hello, I am new to this forum and have always enjoyed working on cars. My dad has a 2008 Tacoma which he bought new. I recently noticed that it looks like there is some oxidation of the paint and was wondering what product or method would be best to get rid of it. The only affected areas are the parts of the truck that were not under that white protective plastic on brand new cars; so its on the front edge of the hood, the A pillars, and on edges of the roof. I do not have an orbital buffer and have tried to get rid of it with Klasse AIO and sealant but it didn't work. I know that the clear coat is still there so it's not like it has to get repainted. Any suggestions on how to remove this oxidation?
well you need some compounding and polsihing to remove it. I use either M105 or Power Gloss with a Uber yellow pad. You can do it by hand, but would recommend getting yourself a DA. Check out the Megs microfiber DA system that phil sells over at detailersdomain. Its a good entry level kit to start with, instead of getting yourself a rotary where you could get into trouble if not experienced. Post up a pic if you can. It would be alot easier to help you out
I am guilty of throwing the word "oxidized" very loosely. I often say paint is oxidized when I really mean they are hazed/discolored due to stains. So sue me. hahaha
Infrared Radiation –IR) represents part of the ultra violet solar spectrum (approximately 55%-60%). The remaining heat source comes from visible and ultra violet light Infrared radiation (IR) infrared radiation is a light source that transmits heat that will cause oxidation by drying out materials, like the paint (binder) resin system (which eventually leads to paint failure) the plasticizers in vinyl, moisture evaporation of leather and the elasticity of rubber causing these materials to dry out and become brittle and compromise their structural integrity
