Honda Odyssey-Using X3 seriously
Discussion in 'Show and Shine' started by richy, Aug 5, 2008.
  1. richy
    Here is a repeat customer from last year although I neglected to post pics of it last year. The cool thing with this one is that I got to really play with my X3 compound and I really liked it. I had tried it once before but the difference this time was using it with the foamed wool..boy does it EVER respond well to that! One thing though, I found that I had better results following it up with 106ff/white pad than I did with X3 and white foam pad. Maybe just me though?:confused:
    The Process:
    Wheels/Barrels/Wells/Tires:
    Wheels & Barrels cleaned with Carbrite acid
    Tires cleaned with ARO
    Wells cleaned with APC
    Tires treated with DP gel
    Wheels polished with XMT 360
    Wheels sealed with DG 105
    Wells treated with Adams
    Wash:
    Bugs pre-treated with DG 471 and washed with bug sponge
    2 bucket method
    WW mf dry
    Paint:
    Clay with clay magic
    Compounded using rotary with X3 and foamed wool at 2000 rpm
    Polished using rotary with 106ff and white foam at 1000-1200-1000
    Cleaned using UDM with DG 501 and blue pad at 3.5
    Sealed with DG 601 & 105 combo
    AW after curing period
    Headlights:
    Compounded with rotary using orange pad and X3 at 1500 rpm
    Polished with DG 681 plastic polish
    Sealed with DG 105
    Exterior Trim:
    Treated with Black Again or 303
    Interior:
    Glass with IG
    Mats vacuumed and steam cleaned
    Rubber mats cleaned with APC
    Carpet vacuumed and steam cleaned
    Plastic treated with 303
    Leather treated with DG 221
    BEFORES:
    AFTERS:
  2. yukonon22
    yukonon22 Wax on..Wax off
    nice work
  3. detaildoc
    detaildoc Guest
    Awesome job :applause:. Great turnaround on that interior.
  4. richy
    Thanks Yukon!!
    Doc..thanks a lot! You should see the interior of the Jimmy I'm working on right now..the driver's floor mat I spent 1/2 hour on for fun. And the rest? You'll see....
  5. GBS
    GBS Wax on..Wax off
    Looks good richy!
  6. P1et
    What can I say, excellent work as usual!!!
  7. Nica
    Well done, nice turn around on that vehicle :cheerl:
    Always a pleasure to see your details richy :druling: Just can never get enough of your neighborhood and the gorgeous homes :thud:
  8. sal329
    sal329 Nuba Guru
    Looks great, nice work for sure
  9. richy
    Thanks Gary. :)
    P1et..thanks bud!!:headbang:
    Carlos..thanks a lot!:thumb:
    Sal..I appreciate the comment.:mounty:
  10. JLs Detailing
    Great work as always richy. Man when you get a mini van you just know the interior is going to be a chore. I did an Odyssey the other day and for those floor mats (which I really liked by the way, very good thought process on them by Honda) I cleaned them and then sprayed them down with DG 253 Tire and Mat dressing and set them out in the sun. After about an hour in the sun I brought them in and gave them a final wipedown once they were reinstalled and they looked phenomenal!
  11. supercharged
    great job!!!
  12. richy
    JL..great tip on the mat dressing. I've tried 303 but it's pretty expensive to use for that. They are an intelligent design, I agree.
    Thanks very much!
