Here is a photo of my problem. I tried warm water and soap and it didnt help. Here is the issue that popped up in the last day. The car has a clear bra over the hood. Any product that would take this out??
If it has a clear coat top coating you might try to polish it out. If not replacement would be necessary. When you get you mind in the set that you need to replace it try to polish it. You have nothing to loose at that point. Had to replace some of mine when it was stained by fresh asphalt.
