help before a little order
Discussion in 'Car Detailing Product Discussion' started by lebreeze, Apr 25, 2010.
  1. lebreeze
    lebreeze Any Rag Vehicle Washer
    Hi guys,
    Just getting rdy to place a little order on DB. Just wanted some advice. Going to start detailing my M3 next week. It's a 08 jerez black with light/med swirls. So far I have power finish and M205. With 1 yellow uber pad, 2 green and a black pad.
    After reading I've learned, I at least need 2 of each. So I was thinking of getting another yellow, another black, 2 blues that I don't have. Should I also get two orange? And also wondering if I should order and other polishes? Thanks guys this forum is the best.
  2. mutmanns
    mutmanns DB Forum Supporter
    I would not buy any orange since you have the yellows. Considering you have a black car I would get a few blue pads as they may finish down for you a little better than using the green for your final polishing step. If you don't want to buy anymore polish, try the powerfinish with the green first. If that doesn't work for your swirls step down to the yellow pad. Use your m205 with the blue pads to finish up before your lsp.
  3. mrgolfrider
    What machine will you be using?
  4. lebreeze
    thanks guys. Porter cable
  5. lebreeze
    Thanks for your help. Just place a order got 2 blues, 1 green, 1 black and another yellow. Also got some uber micro fibers and some uber red applicators. So addicting and expensive :gidiup:
