Head light polishing??
Discussion in 'Compounds, Polishes, Paint Cleaners, and Glazes' started by jason827, Jul 28, 2011.
  1. jason827
    jason827 Any Rag Vehicle Washer
    I gave a exterior detail to my very close fiend's 04 Civic SIR including both headlights polish. We had lunch together a week ago and he told me not to do any headlight polishing for any of my further customers because both of the headlights on his car turned yellow after I polished. He referred to his brother's theory that the 'coating' has been completely polished off from the headlights. I said it woundn't be possible because I have polished couples of headlights with no followed up issue. This include my 03 Toyota SUV with 300k mileage.
    The brother of the owner commutes around 180km round trip a day to work and highway mileage composes most of the trips. I explained the turning of the colour might be caused by the road condition.
    His brother had been using dishes soap instead of car wash shampoo until I convinced him not to. The clear coating on the car is thin in overall, and there is no clear no the front bumper. I guess this is caused by the sand and rock hitting, and this could be the major explanation for the colour turning.
    Any thoughts? Does anyone knows if there is a 'real' coating on headlights?
  2. Chaseme
    Chaseme DB Forum Supporter
    I believe it is common for headlights to have a UV coating. And I have also heard polishing aggressively will remove this coating.
    There is a chemical product available that is said to restore this finish. I'll pull up the article later. I recall the instructions tell you to wear a respiratory mask when applying.
    Whatever sealant you put on probably was broken down by your friends washing product.
    Opti-Coat or AQuarts might be a good product to try.
  3. Chaseme
    As a side note I have noticed Japanese car headlights are more easily damaged than German. American cars seem to be somewhere in the middle.
  4. Innovative
    Innovative Virgin Detailer
    Yes your headlights do have an OEM sacrificial UV coating on them to protect them from the elements. When this coating fails as evident in the photo, this coating will start to check or delaminate from the lens surface......
    Porsche 996 Lens
    After failed UV coating has been removed....
    Both lenses on the bench going thru "Headlight Lens Restoral"
    New UV sacrificial coating applied and cured with a special UV curing lamp
    Headlight Lens Restoral finished and ready for the install
    Installed and looking like new....
    Completed and ready for delivery............
    This restoral is as clear as a CD case, solid and cured......no more sanding or polishing required and no more yellowing...guaranteed!
  5. nth degree
    nth degree Virgin Detailer
    Great write up Inno. For those of us that don't have the special UV coating and curing lights what would you recommend using as a substitute? (Besides the obvious "Bring it to me." response.) Is Opti-coat a viable option?
  6. Kaban
    Kaban Welcome to Detailing
    I want to know where to buy the UV clearcoat... I know it's not expensive and spray kings had them, but their website no longer works. It was about $12 for a 10oz. can.
  7. slanguage
    yeah I would like to get something for headlights as well. some kind of long lasting coating.
  8. GDAL
    GDAL Super Moderator
  9. slanguage
    ok, so how much is the stuff? and where can I get it?
    should i get the uv lamp as well?
  10. GDAL
    Roger ... it's about $40 bucks a can. I don't know how many you need per set, but I think one can should be fine for a normal light set. You can buy this stuff online.
    The UV lamp (400w UVA lamp) is about $200-240 bucks. I have read everywhere that the uv lamp is not necessary if you leave the lights under the sun for a few hours. The lamp speeds up the process (2 min per light), but it's not a must for enthusiasts.
    The only way I could justify buying the lamp is if I had to do several headlight restorations a day.
  11. Kaban
    I agree. The lamp is too expensive for a weekend worrier or even a pro unless you do ALOT of these permanent light restoration on a daily or weekly basis.
    How many coats of this clear coat should you apply per light? Do you wetsand and buff it once it cures to remove orange peel?
  12. Chaseme
    Gdal. Thanks for the heads up on the UV light.
    I wonder if headlight removal is necessary. Or if tape will do.
  13. nth degree
    If your doing that quality, removal should be done. They really are much easier to work on in the open.
  14. nth degree
  15. Kaban
  16. jason827
    I live in the Greater Toronto Area. Do you know any place that sells the UV coating? I have checked Home Deport and Rona but they never carried the product.
  17. slanguage
    $40 bucks a can is nuts. I'm going to call ardex today (hopefully), and see what they charge for their stuff.
    Thanks for the info G, and I'll let you know what Ardex says. I do know they sell a kit, and a banner.
    http://www.ardexwax.com/uploads/Accessory_Catalog_4.30.pdf
    scroll to page 23.
  18. GDAL
  19. GDAL
    Let us know Roger. I might have to go to Philly to pick some of this stuff. Thanks again bro!
  20. chefwong
    chefwong Birth of a Detailer
    What I've done in the past is to correct and then apply 3M PPF film on it----which has a UV topper on it (some films dont). 3 years later, still looks good...
