HD Dress: Gloss Adjustable Exterior Dressing Introducing HD Dress. An exterior water based dressing designed to shine, darken & protect exterior non-painted porous surfaces including, tires, textured trim & engine compartments. This dressing doesn't sling, is not greasy and is very easy to work with. 2 things that I love about HD Dress is the Bubble Gum scent and its ability to allow the user to alter the level of shine. From extra shiny to a satiny mat look. 1 uniform coat will deeply darken and give a great shine. 2 coats create a shiny high wet look. Gently wipe and with a towel and adjust the level of gloss. Apply to your choice of applicator. In this case I'm using the 3D dressing block. No need to over apply the product. Initially just enough to coat most of the key areas of the applicator. Once applied, add 3-4 more drops as needed. A little goes a long way. Here is what the shine is like after 2 full treatments: Check out this 50/50: To alter the gloss, take a scrap cotton or Microfiber towel and lightly wipe: Here is the difference from Shiny (9 o'clock to 12 o'clock) to semi-matt (12 o'clock to 3 o'clock) Finished product: http://youtu.be/g6DCr56xFQ8
It has silicone in it, so yes. But keep in mind that it's water-based, so like any other dressing like this you won't be able to drive through a rain storm and have your tires look identical after.
