Hard water spot help!
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by chemgys99, Jul 9, 2012.
  1. chemgys99
    chemgys99 DB Forum Supporter
    I have really bad water spots on this customer car I'm doing. Is there any ways to get this off? I don't have any hard water remover at the moment. Is there any home remidies to remove them? Thanks in advance.
  2. React
    React Birth of a Detailer
    CG water spot remover, clay, polishing (least to most aggressive). Unsure if anything else will work.. gl!
  3. chemgys99
    Car goes out tomorrow. Don't have time to get any water spot remover.
  4. vtec92civic
    vtec92civic Nuba Guru
    what was listed above . . . . you can also try white vinegar to help break the spots up.
  5. drew935
    drew935 Auto Salon Works
    Do you have nanoskin? It removed most on them on my neighbor's car except for the etched ones. Or else try the vinegar.
  6. chemgys99
    Ok I'll give vinegar at try. Does it work well on windows. That's the main concern.
  7. Rcrew
    Rcrew Wax on..Wax off
    If the vinegar doesn't work...on a very clean window (other than the spots) use 0000 steel wool and a fine polish like super finish or 85rd. Use light to medium pressure and inspect often to make sure you are not scratching the glass. If that doesn't cut it do you have a polisher?
