Hard vs. soft: The final thread!
Discussion in 'Car Detailing Product Discussion' started by bigfoot, Dec 23, 2008.
  1. bigfoot
    bigfoot Jedi Nuba
    Well, guys and gals, there has been a huge rave about this Dodo Juice waxes and tons of questions between the soft and the hard ones. When you look at the collection of waxes they have, it's a total of 8 waxes without adding Supernatural or the AIO and soap. I have decided to make an honest review to kinda end the arguments of which one might be the best in matter of application, ease of use and overall, durability.
    The test subject was the trunk lid of my 2000 grey Echo, which is not a big spot, but big enough for what I was looking to do. The waxes being used are Rainforest Rub(soft) and Hard Candy(hard) which I just got yesterday (David, A.K.A weekendwarrior, you rock! :thumbs: ) The method of application was the same: microfiber applicator. Weather here in PR for the next few weeks seems to be on the warm, not hot side: mid 80's with occasional rainshowers passing by. So, with that said, I plan to make this an ongoing thread.
    Now, into the action. I decided to polish the trunk using OHC and OC since it was pretty scratched to start with. I divided the trunk in 2: left for RR and right for HC. As said, method of application was the same for both waxes, left to cure for around 5 minutes, and buffed off using Danase Buff Towels.
    The contenders
    The prepped surface
    First one to be applied was Rainforest Rub. I used a little to spread it on the half designed for it. Found out a very little goes a very looooong way. I applied a hefty coat on the trunk and see how hard was to take it off vs. a layer of the hard one beside it. Aplied and let cure for 5 minutes.
    Now, the Hard Candy. Used the same method as the previous wax, but it was more difficult to get a thick layer of wax on the surface, which I think it helps in making the wax last longer. Applied in the other half of the car and this is while curing
    After 5 minutes they were buffed out and here are my findings. Both waxes look around the same after being buffed. As expected, RR was a little more tricky to take off due to the application thickness, but not as bad as expected. Reflection shots will come out later, as well as beading shots and reviews on durability. Here are 2 more pics so you can have an idea how they look.
    I will be updating this thread with any of my findings and if you have a comment or a question, just shoot it out.
    Joey
  2. Buddy
    Thanks bigfoot, This sounds like an interesting review process...Since I have never tried these waxes...:thumb:
  3. ScottieB
    ScottieB Jedi Nuba
    Subscribed!
  4. Denzil
    Thank you for conducting this test. I still have to test out the Straight Kit myself.
  5. matrix_808
    matrix_808 DB Supporter
    cool, cant wait for the review. i always find myself trying to test waxes, but i end up getting too anxious and end up reapplying a second coat.
  6. bigfoot
    bigfoot Jedi Nuba
    48 Hour Review
    Hello everybody! Here’s an update to my continual test for the hard vs. soft waxes based on what I have seen in the past 48 hours. What I have seen so far is the following: slickness still the same on both, looks are awesome still and beading is beautiful! The only negative I have found is that they attract a little too much dust, IMO, but all waxes do it to an extent. Here are some pics before and after a wax, plus some beading shots at nighttime. Again, comments are more than welcomed. Here are the pics:
    First off was the dust test. I found both attract dust the same.
    Rainforest
    Hard Candy
    Both fingers side-by-side
    The funny thing is that when I decided to start pulling the car out of the carport, it started to rain
    So after letting that rain pass, I pulled the car back and this is how the waxes look like in direct sunlight
    Rainforest
    Hard Candy
    The car was washed and dressed with some #16. The car needs to be heavily polished, but it will take me around 2 days because it has some nasty scratches and holograms from I don’t know what. Then after that I had to go out at night to help a friend install a router and it rained, and this is how the waxes are beading that water.
    Rainforest
    Hard Candy
    Joey
  7. Denzil
    Thanks for the update Joey!
  8. DG 501
    DG 501 Jedi Nuba
    Thanks for the update and taking the time Bigfoot!
  9. NCZ13
    NCZ13 Birth of a Detailer
    hm ill have to try using a MF applicator with my dodo hardwaxes.
    I used a foam one yesterday on mine. I used Diamond white, and it felt like the pad was dragging and marring my finish...
  10. Buddy
    Hi bigfoot, Thanks once again for sharing and your hard work...Real nice job...:thumb:...:thumb:...:thumb:...:thumb:
