Hard and Soft Paints
Discussion in 'Car Detailing Product Discussion' started by togwt, Feb 21, 2009.
  1. togwt
    Hardness: [In materials science, hardness is the characteristic of a solid material expressing its resistance to permanent deformation. There are three principal operational definitions of hardness: Scratch hardness, Indentation hardness, Rebound or dynamic hardness]
    A sound understanding of the proper technique and the correct process will produce excellent results even with a mediocre product. A quality product used without the proper surface preparation or application technique will never obtain a satisfactory result. Using the proper methodology (surface preparation, using a quality product, along with the correct application technique) will ensure an excellent result.
    Skill Level / Experience
    Some methods described may be beyond the capabilities of the average detailer or enthusiast; in this case we strongly encourage the reader to consult a professional detailer or body shop concerning the matters discussed herein.
    Liability
    The writer assumes no responsibility, expressed or implied, due to misuse or misinterpretation of the information or methods used, or for any vehicle damage or injury that may occur due to the suggestions and information offered.
    Product Quality and Technique
    Proceed with this in mind; the products you use constitute a very small factor in the equation. Methodology and technique constitute 95%; the reasoning behind the choice of quality products is to eliminate any limiting factors, thus enabling you to place emphasis on technique used.
    OEM Paints
    PPG Protective and Marine Coatings, DuPont™ Performance Coatings, Spies Hecker® (part of DuPont, used mostly by European auto manufacturers) and BASF coatings, each of these companies have a range of several differing paints
    Water based paints
    Water-based automotive paint is classified as a semi-permeable membrane that has tensile strength and elongation (elasticity) to enable it to move along with the metal as it expands /contracts due to environmental temperature fluctuations Paint is a simple mixture of ingredients including pigments, a binder and diluents, or thinner (in a water-based paint it is water; in a solvent-based paint, it is petroleum solvent). Automotive paints utilizing modern paint technology using water-based high solid/low solvent urethane that for environmental reasons produce a much softer and more porous finish than acrylic or oil based high solvent content paint systems. Water-based automotive paint is classified as a semi-permeable membrane that has tensile strength and elongation (elasticity) to enable it to move along with the metal as it expands /contracts due to environmental temperature fluctuations
    Using permanent pigmentations and colorants specifically designed for automotive applications (containing automotive-grade binders). Albeit a non-toxic (less than 0.01-percent VOC) water-based paint, there are no compatibility issues with major-brand urethane and polyurethane clear coats.
    Hardness
    Is defined as the ability of a material to resist local deformation (or penetration) from externally applied pressure, and is directly related to its tensile strength; stronger materials are generally harder. The enamel paint finishes on vehicles from the 50’s and 60’s era were as tough as porcelain. But rightly due to environmental concerns, those high percentage petroleum based paints have been generally superseded, resulting in the softer water-based paint finishes of today and the unavoidable orange-peel seen on many new and re-painted vehicles.
    Today’s paints, unfortunately, rank somewhere near the bottom of the scale of hardness, especially single coat black / red paint the exception being white single stage and Ceramiclear, when compared to all the materials your paint can possibly come in contact with (always bear that in mind).
    An adaptation of that hardness scale( 1 - 10);
    Talc = 1
    Carbon Black [black paint pigmentation] = 2
    Glass = 6
    Titanium dioxide [white paint pigmentation] = 7
    Diamond =10
    Hard and soft are relative terms; you can scratch the hard surface of a vehicles paint with a soft towel by the application of enough pressure. Both pressure and mechanical stress are defined as force per unit area. These two forces are the subject of Newton's third law of motion; the law of reciprocal actions [: to every action there is an equal and opposite reaction]
    How can a hard clear coat be so easily scratched? A force acts through a body that has a surface area; if the surface area is really small while maintaining an equal force, the pressure becomes astronomical and the object under pressure capable of penetrating the surface of an otherwise tough material. That’s why a micro fine thread in an otherwise soft towel will scratch your paint and the same reason a mosquito can penetrate a rhino hide with its proboscis (stinger).
    Note - Heat makes solids softer; cold makes them harder. Keep that in mind when detailing (especially polishing) your car in the sun or on a really, really hot day.
    Hard / Soft Clear Coats
    Each vehicle assembly plant uses different clear coat paint from one of three major paint suppliers; PPG, DuPont, and BASF products and each of these companies have a range of several differing paints
    1. Some vehicle manufacturers have more than one plant assembling the same model of a vehicle; each plant will often use a different supplier for the clear coat paints.
    2. Each assembly plant may elect to use one of several OEM paints from PPG, DuPont or BASF clear coat product lines.
    3. There are other factors that will have an effect; the composition of the clear coat used (single, duel component, or powder) this generally reflects the trade off the OEM is prepared to accept between scratch resistance and gloss level considered acceptable, oven drying time and its temperature, the relevant age (i.e. how long ago was the paint applied) spot panel repairs (refinish) that are carried out either at the assembly plant or the rail head or port of entry. This is also true of imports assembled in the US; usually one paint supplier is approved for all plants; however each plant may modify the application/bake process in order to meet production demand. This may also affect which has the harder or softer clear.
    Diagnosis is the key, not guess work; before deciding on what products to use ascertain the paint surface conditions;
    Paint thickness
    New or Aged, Single stage or Clear coat, Oxidized, Soft or Hard or CeramiClear etc choose a panel and test your proposed foam pad / polish / machine speed process. Once you are satisfied that this process will give you the finish required, proceed to polish the rest of the paint surface. The more abrasive combination you have to use to see results, the harder the paint.
    Using the least aggressive pad / polish combination followed, if necessary by an incrementally more aggressive approach until you find what works.
    Hard paint - does not mar as easily, but it's more difficult to polish surface defects.
    Soft paint- is very easy to polish out surface defects, but easier to induce surface marring.
    As always generalizing carries a degree of risk as a panel(s) may have been re-painted
    Information resource
    Automotive Detailing Inside & Out; a Knowledge Base for the Perfectionist– by Jon Miller
    © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved
    Detailing Articles
    Copyright Protection and intellectual property rights-© This work is registered with the UK Copyright Service that supports international copyright protection by securing independent evidence that will help prove originality and ownership in any future claims or disputes.
    All original material is copyright, unless otherwise state (1) it may be copied and distributed for non-commercial purposes only provided that you retain all copyright and other proprietary notices contained in the original material, (2) the information is copied in full with no changes unless prior written agreement is obtained from TOGWT, and a reference to © TOGWT ™ is included, any unauthorized use of these materials may violate copyrights and/or trademark. Be aware these files have been digitally watermarked and actually contain embedded copyright information; so they can be traced to any website on the internet if needed in a legal confrontation
  2. Wolfs Chemicals
    Hi again, Jon :) Quick question for you: I'll be doing this on Monday
    And the door panels will also need to be polished. To the best my knowledge, the lacquer used on carbon fiber is not too much different from clear coat. Am I right? Anything special I need to know about polishing carbon fiber? I have and M6 customer and his roof is CF... it had a stone chip in it and started coming off like a layer of rock chip film... it was odd and felt like it would be very sticky to polish. Maybe Paul D. would also have some input on this one from the Koenigsegg he did? Thanks!
  3. togwt
