Hand polishing ???????????
Discussion in 'Car Detailing Product Discussion' started by Beast Mode, Apr 9, 2010.
  1. Beast Mode
    Beast Mode Virgin Detailer
    I have a sports bike and would like to polish the plastic body. I think there are too many sharp edges to machine polish. What kind of pads and polish would be a good combo for hand polishing?
  2. 911Fanatic
    Have a look at the hand polishing pads we carry, here. They work extremely well. I used the orange one with M105 to remove wetsanding marks on the Shelby I'm working on.
  3. Beast Mode
    Would I have to prime the hand pad like normal pads?
  4. 911Fanatic
    You can if it makes you more comfortable, but usually I just put a bead of polish down the center of the pad and have at it.
  5. richy
    If it's a small enough area, I just put some polish on a mf and use that. Just like you would under door handles.
  6. TWISTEDFRAME
    TWISTEDFRAME Jedi Nuba
    I have several clear coated carbon fiber parts under my hood I would like to polish before I seal them next. Is it worth stepping up to a hand pad or does the MF method work well enough to not spend the extra money for just a few parts? Thanks.
  7. 911Fanatic
    I used mf for a long time and found the pads will cut the time down considerably. If they didn't work, they wouldn't be in my store. :)
  8. TWISTEDFRAME
    thanks for the quick reply!
  9. izzypizzy
    izzypizzy Virgin Detailer
    My car was recently damaged by a faulty car cover, the thing wouldn't stay on in the wind. The scratches are pretty minor, but I can see them and that bothers me.. They're only in 2 small areas, above the right rear tire and above the left drivers door.
    I don't own any polishing equipment, so I was wondering just how effective using one of those hand polishers would be? I'd be willing to buy a pad and some polish if it would do the trick. Would I need one pad/polish for cutting and a different combo for smoothing it out afterward?
    Thanks for any advice:)
  10. vtec92civic
    vtec92civic Nuba Guru
    nice one Ken. I never knew Menzerna made pads and i also would use a microfiber to catch some small stuff but you're the man and if you say those work i just might have to get some LoL.
  11. Depends on the severity of the scratches. Regardless, the orange pads Ken(911 Addict) was speaking of I feel everyone should have anyway :hmph:
  12. izzypizzy
    They're not easily visible except in the right lighting, so not too severe. Which polish would you recommend with the orange pad? Thanks :worship2:
  13. christian900se
    Which polishes do you have? My personal favorite polish by hand is Meguiar's Ultimate Compound as it is one of the few polishes I have used by hand that produces a finish similar to a machine session while being able to actually remove defects. Technique is most important when working with hand, I find that the best results for me come from the following technique:
    -Begin with heavier pressure and work in alternating back & forth motions and the tradition orbital 'waxing' motion
    -As the polish breaks down, use less and less pressure on the polishing pad to eliminate the potential of leaving any micro marring.
    -The last few passes should be done with minimal pressure to get the sharpest reflection and finish.
  14. izzypizzy
    Thanks a lot for the info! I don't own any polishes, I'll be picking up one of those pads and I'll probably give the polish you recommended a try. Thanks again.
  15. izzypizzy
    So checking back in.
    I purchased the orange hand pads and the meguiar's ultimate compound and went at it.. It helped a little, but man is hand polishing tiring for the results. I wish I could afford a machine to do it right, or to pay someone to do it. Somewhere down the road I will.
    Thanks again.
