When cleaning the interior of a car, the most stressful part for me is getting all the hair out, especially if you have black interior. So how do you get all the cat/dog hair out of the carpets?
I use rubber gloves and just rub my hand over the hair creating a little bit of friction. I get the hair in a nice pile and just vacuum it up. I've tried everything and this has been the best method by far.
On the CG website they have a roller thing that grabs up all the hair, but do you think it can slowly rip up the carpeting in the car also?
Removal of animal hair (Carpets): 1. Solution 10:1 Fabric Softener / Distilled water. Its anti-static properties help to release the hairs from the carpets fibres. The scent will actually help to destroy odour since most contain anti-bacterial agents. 2. Distilled water / Woolite 10:1 Powerful Vacuum A pair of household rubber or latex gloves Techniques used: 1.Vacuum the area first. This will remove any loose hair and surface dirt. 2.Wet area down with the fabric softener mix, but do not soak. 3.Allow to dwell for 5-10 minutes. 4.Turn your vacuum on and place the nozzle at an angle close to the area to be worked. With one hand, rub the carpet with some pressure in a sweeping motion towards the nozzle. The hair should pile up. I now lightly spray the area with a solution 10:1 Fabric Softener / Distilled water
