Grit Guards vs OTC 5 gal buckets
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Dial Up, Dec 26, 2009.
  1. Dial Up
    Dial Up Birth of a Detailer
    So which OTC 5 gal bucket(s) will Grit Guards from i.e. DB, DI, CG, and so on
    fit "properly" in? :computer:
  2. Cooter
  3. pektel
    pektel DB Forum Supporter
    What I did was just measure the grit guard. Then when you go into a home depot/lowe's, just grab on of their tape measures from the tool section before heading to the buckets.
  4. agpatel
    agpatel OD On Detailing
    Just take the GG with you and go to home improvement stores and put them in it. Also check out the cake section of a grocery store they get icing by the 5 gallon pail and they fit the GG.
  5. Cooter
    Another member here (zoomzoommazda5) says you can go by the Deli in WalMart and they'll give you the 5 gallon icing buckets.
