I want a Griots polisher but do you have to use only Griots pds or can you use any velcro-backed pad, like Lake Country? Also, can a brush be attached like you can on the PC?
i believe the griots DA also have hook loop system which means yes you can use velcro-backed pad. brush.... yes probably with the proper backplate shouldnt be a problem.
Yes it uses a hook & loop system so any hook & loop pad and accessory like the carpet brush will work with the Griot's Garage setup.
