Hi Dylan, Will the brilliant glaze work well if applied using this polisher with uber blue (glaze/finish) pad? Thanks.
it will either work, or create a huge vortex and the world as we know it will be sucked into a hole of doom about the size of a almond.................... good luck!
new to detailing so might have been a stupid question...not sure about product compatibility. Plus I thought that adam's products are only designed for use with PC.
Don't sweat it R-Q5... better to ask and be sure than not ask and end up with some unexpected result. In the end the movement and function of the PC, GG6, and other polishers is very similar, pretty much identical so the function of the products you're using would be the same. You can pretty much rely on all the info we have for PC usage and apply that to your polisher.
