Grime Reaper & Premium Blue
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by Cooter, Jun 21, 2008.
  1. Cooter
    I got 16oz of each in a trade. Just wondering if both of these dilute or if you just use them at regular strength. If you can, what do you recommend as a dilution ratio?
    Heath:devil:
  2. Dust2Glory
    Dust2Glory Nuba Guru
    Premium blue is 1:1....
    Grime reaper is like 1gal of GR can make 5-8 gal... So u do the ratio on that, I suck at them.
    They were both kind of a let down for me.... Had sample of PB and I still love me some megs wheel brite!!! Grime I got now, using for tires and wheel arches and doesn't seem to cut dirt like an "acid"
  3. Cooter
    What about as a degreaser under the hood?
    Dust, i suck at math too. Is there 128oz in a gallon? So that would be like 1/8 of a gallon. Man, i might just trade it hehehe
  4. pirex
    pirex DB Certified Dealer
    I love grim reaper. But I like to cut it 1:1 or a bit more water. It remove dirt really nice
  5. Cooter
    Thanks Pirex!!
  6. pirex
    I know CG says 1 gallons gives you 5-8. But thats a bit marketing, seems cheaper tha way. But I guess that 16 oz bottle can give you 3 16 oz bottles. Take the one full strenght in a bigger bottle, and add 2 16 oz bottles with water.
  7. JLs Detailing
    Ok guys if 1 gallon of product can make 5 when diluted thats a 1:4 mix. 1 part product (1 gallon) and 4 parts water = 5 gallons of finished product. So if it says 1 gallon of product makes "X" number of gallons just subtract 1 from the "X" number and thats the dilution rate wether it be gallons or ounces. Its a ratio so doesn't matter the unit of measure.
    Now I use Grime reaper 1:4 and it does fine on wheel wells, tires and engines. It could be a little stronger so on my next mixture I might go 1:2.
  8. Deep Gloss Auto Salon
    I do 1:1.5 and it works like a charm... When comparing the price to P21s TAW I may I may revert back to 1:1 so I will not need to worru about "what it will handle"... 1: 1 and you are set for it all!!
  9. er1k
    er1k Obsessive Detailer
    Never had any experience with Grime Reaper but I do have Premium Blue and I will say that I feel it's an okay product. It will tackle the dirty wheels except excessive brake dust. I still have yet to try out P21s Wheel Gel though.
