1. kustomizingkid
    kustomizingkid Nuba Guru
    So I've been using strictly a rotary since I started this insanity and just finally got a PC... bought it because ummm... why not?
    So what is better to do with the PC than the rotary?
  2. slanguage
    you can apply waxes with a PC. I have done spot correction with one also.
  3. Reflect
    If you get a PC Guard from show car detailing, you can work a pad under doorhandles to get at the scratches. On some plastic pieces, it may be better to use a PC due to the heat generated by the rotary.
  4. pektel
    pektel DB Forum Supporter
    A couple of big advantages: A pc's performance is not affected by sticky paint. So now when you run across a vehicle with the issue, just use the PC.
    The second advantage is applying sealants.
  5. bimmer nation
    bimmer nation Birth of a Detailer
    sealants for sure also if you want to do some jewling i love using my pc for it
  6. Denzil
    I keep forgetting about that nifty little tool accessory. I'm going to have to remember to pick one up soon.
  7. agpatel
    agpatel OD On Detailing
    Great for waxing, glaze, final polishing on a uber soft paint, bumpers, glass polishing..
