Gilmore foam gun
Discussion in 'Pre Wash, Wash, Decon, Claying, Engine, Wheels, an' started by mobilejay, Jan 8, 2011.
  1. mobilejay
    mobilejay Birth of a Detailer
    I have had this foam gun for about a year now. The sprayer is kind of broken and it can be a pita to use sometimes. Does anyone know if I can just buy the sprayer that the canister attaches to instead of buying a whole new unit?
  2. mobilejay
    Oh come on guys, someone's got to know this LOL
  3. kyoshiro
    kyoshiro DB Forum Supporter
    prob send an email to gilmour and see if they can send you just the sprayer, else DIY with some sheets of metal and a hammer :D
  4. mobilejay
    LOL well I won't be doing the DIY thing, I will just make it worse. I didn't think about talking to Gilmour which seems like the way to go, thanks.
  5. detailersdomain
    are you talking about just the orange trigger sprayer?
    all we do at the shop it hook up a quick connect to a shut off valve.
  6. mobilejay
    Yeah the trigger sprayer. Do you have a pic of your hook up?
  7. Danny
    Danny Nuba Guru
  8. kyoshiro
    i would believe this setup be like
    [canister] [quick connect] [shut off valve]
    another way is
    [canister][hose]
    so if u want to use a gun like trigger, buy another spray gun. it'll prob cost the same as a shut off valve. quick connect is a plus if you dont want to screw it in every time.
  9. mobilejay
    Thanks for the links Danny, but the trigger has a black piece in the front that you pull back to attach the canister. Then it clips in place. Kyo, thats the thing. I don't want to have to unscrew it all the time, when I clay a car I foam a panel, clay it and rinse it. If I had a shut off valve it would be a pain to remove it every time.
  10. kyoshiro
    yep then what you need is the quick connect thing
    like this
    if you can take a picture of the part, i can prob think of some ways to ghetto fix it without having to DIY a piece of metal plate lol
    and also i believe the click front to canister is the quick connect so just finding a match end may work
    edit:
    and via some googling!
    simply get a new quick connect end that matches the sprayer then you're golden
  11. Danny
    Danny Nuba Guru
    yeah thats what the second link is man that just a different brand but its that same thing it a quick disconnect:)
  12. Socal Brian
    Speaking of th Gilmour foam gun you guys have an opinion on the original vs the foamaster II?
  13. Socal Brian
    Amazon.com has both
  14. mobilejay
    Awesome, I'll probably work on it this weekend. Thanks again guys
  15. racedoc11
    racedoc11 Any Rag Vehicle Washer
    If you end up looking for a new one ADS has it for $39
    here is the link
    Gilmour Foamaster Gun
  16. mobilejay
    Cool thanks for the link
